Results 1 to 3 of 3
Thread: $
    Aug 2005
    down south
    Default $
    I'm learning to program in pbp-cdlite and looking at some code that I found, I saw this not sure but is "$0" and "$90" reseting all the flags and interupts.
    in the OPTION_REG. AND INTCON
    please explain
    MAIN
    OPTION_REG=$0
    ON INTERRUPT GoTo bump
    INTCON=$90
    just trying to learn, asking for a little help
    thanks
    $ is just a tag that mean it's a HEX value.
    The PBP default 'radix' (if i can call it like that) is dec. So when you want to use Binary or Hex value, you must tell to the compiler.
    MyVar=10 <= 10 decimal
    Myvar =$90 <= 90 HEXadecimal
    MyVar=%11110000 <= Binary value = $F0 = 240 decimal
    please explain
    MAIN
    OPTION_REG=$0
    INTCON=$90
    Hard to say what it does if we don't know the PIC model. BUT many times, some of the interrupts flags are reset in the INTCON register.
    Better and safer if you refer to your PIC datasheet to see what it do.
    In my case, i prefer to use Binary as value. Easier to refer to the datasheet after few months/week/year/Century/milenium ...
    INTCON=%10010000 is easier to figure out with the datashet than INTCON=$90 IMHO once again.
    Also use Alias/Symbol to access directly to a specific register bit, Let's say
    RCIF    VAR PIR1.5   ' USART rx interrupt flag => Buffer full/empty
    GO_DONE VAR ADCON0.0 ' ADC conversion status bit
    Aug 2005
    down south
    thank you mister_e
    I had alway used the $0 and $90 because a guy sent me some code and he used it. but I did not know what it meant. but it worked.
    I 1st.did the code below with it and it worked. and then I did the code looking things up in the data sheet (like you suggested) and again it worked.
    INTCON.4=1 'ENABLE RA2 EX. INT.
    OPTION_REG.6=0 'SET RA2/INT FOR FALLING EDGE
    INTCON.1=0 'RESET RA2/INT
    ON INTERRUPT GoTo BUMP
    I was thinking it might be some kinda wild card that reset everything.
    don't laugh at my code I just learning.
    DEVICE pic16f630
    @ DEVICE pic16f630, INTRC_OSC_NOCLKOUT
    @ DEVICE pic16f630, WDT_ON
    @ DEVICE pic16f630, MCLR_OFF
    @ DEVICE pic16f630, CPD_OFF '16F630 TEST
    @ DEVICE pic16f630, BOD_OFF
    @ DEVICE pic16f630, PWRT_ON
    @ DEVICE pic16f630, PROTECT_OFF
    Pause 20000 'ALLOW TO STABILIZE AFTER POWER UP Allow
    TRISA = %00101100 'MAKE A.5,A.2 & A.3 INPUTS
    TRISC = %00000000 'MAKE ALL PORTC OUTPUTS
    OPTION_REG.7 = 0 'ENABLE PULL-UPS
    WPUA = %00110111 'WEAK PULL-UPS ON PORTA
    SYMBOL GREEN = PORTC. 'GREEN LED
    SYMBOL TRIG = PORTA.2 'INTERUPT INPUT
    SYMBOL NOW = PORTA.5 'NONE INTERUPT INPUT
    SYMBOL ORG = PORTC.2 'ORG LED
    SYMBOL RED= PORTC.3 'RED LED
    TRIG= 0
    GREEN = 0
    NOW = 0
    ORG =0
    RED =0
    GREEN=1 'power up ok
    Pause 4000
    GREEN= 0
    Pause 2000
    IF NOW =0 Then GoTo LONG 'SELECT LONG OR BUMP
    GoTo MAIN
    MAIN
    'OPTION_REG=$0
    'INTCON=$90
    REFRESH:
    Sleep 20 'EVERY 20 SEC. TURN A DIFFRENT LED ON FOR 6SEC. THEN OFF
    ORG=1
    Pause 6000
    ORG=0
    Sleep 20
    GREEN=1
    Pause 6000
    GREEN=0
    Sleep 20
    RED=1
    Pause 6000
    RED=0
    GoTo REFRESH
    Disable
    GoTo MAIN
    BUMP:
    GREEN = 1 'GREEN LED ON
    Pause 1500 'FOR 1.5 SEC.
    ORG=1 'ORG LED ON
    RED = 1 'RED LED ON
    Pause 3000 'HOLD FOR 3 SEC.
    GREEN=0 'GREEN LED OFF
    ORG=0 'ORG LED OFF
    RED=0 'RED LED OFF
    INTCON.1=0
    Disable
    GoTo MAIN
    LONG
    GREEN=1
    Pause 3000
    GREEN=0
    Pause 1000
    RED=1
    Pause 3000
    RED=0
    Pause 1000
    ORG=1
    Pause 3000
    ORG=0
    INTCON.1=0
    GoTo LONG
    Enable
  1. PBP projects for R/C models
    By malc-c in forum Code Examples
    Last Post: - 21st October 2016, 12:56
  2. lambda probe interface IC - CJ125 from Bosch
    By almarto in forum Off Topic
    Last Post: - 29th March 2011, 18:36
  3. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 22:33
  4. SHIFTOUT Clock rate
    By Brock in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 23:42
  5. does this piece of code look ok?
    By Richardco in forum mel PIC BASIC Pro
    Last Post: - 30th November 2005, 20:34
