A little HELP!!
Results 1 to 40 of 77
Thread: A little HELP!!
    Mar 2011
    Los Angeles, California
    Default Re: A little HELP!!
    That seems kind of strange to me. Any ideas as to how we can test this? Maybe something simple like assigning a color to "NTSC"?
    I have looked at the BOB4 from decade.net and it looks like their version only does white text on incoming video.
    http://www.decadenet.com/bob4/bob4.html
    I believe the STV chip was really designed for Menu setups on televisions etc, prior to digital sets, and does not to put color text overlays in incoming video, other chip maker versions also no colour, 1990-2000ish did the same, Maxim, Sanyo.
    With digital sets it is now incorporated in a graphics chip onboard.
    This is where you can change the character color, it will affect all characters using this routine, text and overlay.
    DISPLAYCHAR:
    WDATA = %0001010000000000 + STVCHAR
    ' 11 10 9 8 7654 3210
    ' WDATA = %0001 0 1 1 1 0000 0000 + STVCHAR
    ' bit 11 = character background 0 = disabled 1 = enabled
    ' bit 10 = red
    ' bit 09 = green
    ' bit 08 = blue
    ' 000 = black
    ' 001 = blue
    ' 010 = green
    ' 011 = cyan
    ' 100 = red
    ' 101 = magenta
    ' 110 = yellow
    ' 111 = white
    Mar 2011
    Again my biggest thanks. I will play with it as time permits. Yes I had looked at the BOB4 sometime ago and it was only white from what I remember.
    Eagle Tree ( http://www.eagletreesystems.com/inde...product_id=136) does color text over video, however they would not share any information to customize their product for other purposes such as a sub. This is why I went back to the STV5730. I spent many hours and days searching for a chip to use with no success. Logically speaking, if you can add color text to a fixed color background then you had to generate the background color as well as the color text and "mix" them to produce video. RGB is kind of a strange animal as it can be RGB video and a separate sync or RGB with sync for each color (R-G-B). Maybe I was searching using the wrong search words and missed finding other chips?
    Mar 2011
    Hi Aerostar!
    Somehow I screwed up my working file and now I have rows 1-9 as white squares while rows 10 and 11 are X's! I have done something stupid just not sure what after several days of trying!
    '*  Name    : NTSC -RPM-V2                                            *
    '*  Author  : Ed Cannady                                        *
    '*  Notice  : Copyright (c) 2017                                *
    '*  Date    : 06-30-17                                          *
    '*  Notes   : VIDEO IDENT                                       *
    '*          : WITH GREAT HELP FROM AEROSTAR                     *
    ' WORKS USES SYNC FOR SWITCHING BETWEEN MIXED AND FULL TEXT MODE
    ' GOING FROM VID IN TO TEXT AND BACK TO VID IN
        __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    '@ device PIC16F628A,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON  'AEROSTAR SET UP
    define  OSC 20
    '16f628a  ED definitions
        TVSDA        VAR PORTB.4    '0     OUTPUT to pin 11 of stv chip
        CS0     	 VAR PORTB.6    '0     OUTPUT to pin 13 of stv chip
        TVSCL     	 VAR PORTB.5    '0     OUTPUT to pin 12 of stv chip
        SYNCH0       VAR PORTB.7    '1     INPUT  to pin 7  of stv chip
        ZOOMREG      CON %0000000011001100       ' 12 ZOOM REGISTER
        COLREG       CON %0000000011001101       ' 13 COLOUR REGISTER
        CONREG       CON %0000000011001110       ' 14 CONTROL REGISTER
        POSREG       CON %0000000011001111       ' 15 POSITION REGISTER
        MODEREG      CON %0000000011010000       ' 16 MODE REGISTER
    	ICOUNT  	 VAR BYTE
    	BITCOUNTER 	 VAR BYTE
    	WDATA   	 VAR WORD
    	CHARCOUNTER	 VAR BYTE
    	LINECOUNTER	 VAR BYTE
        STVCHAR      VAR BYTE
        ASCCHAR      VAR BYTE
        CHARS        VAR BYTE
        CHARS2       VAR BYTE
        TEMP         VAR BYTE
        TEMP1        VAR BYTE
        COUNTER      VAR BYTE
        PULSES       VAR BYTE
        CURRENTMODE0 VAR BYTE
        PRPM         VAR WORD
    '    TOPLEFT         CON 0
    '    TOPMIDDLE       CON 5
    '    TOPRIGHT        CON 10
    '    BOTLEFT         CON 2560    '10*256
    '    BOTMIDDLE       CON 2565 '(10*256)+ 5
    '    BOTRIGHT        CON 2570 '(10*256)+ 10
        DATA @0,"NTSC.",$FF,"NO SYNCHS RECEIVED",$FF
        TRISB = %10001111
        PAUSE 500
    	GOSUB Init
        PAUSE 500
    	GOSUB Init
        CURRENTMODE0=255         ' FORCES TRYSYNCHS TO SET MODE FIRST TIME
    Demo:
    CHARCOUNTER = 0
    	LINECOUNTER = 0
    '   CURRENTMODE0 = 0     '0 = MIXED 1 = TEXT
        gosub CLS
        GOSUB TRYSYNCHS      '==================================
        TEMP = 0
    LOOPER:
        GOSUB HEADER    ' LINE 3 RIGHT HAND SIDE TEST.
        GOSUB FILLSCREEN
        STOPHERE:
        GOTO STOPHERE
    '    PRPM = 6789
    '   IF CURRENTMODE0=0 THEN   ' ONLY WHEN INCOMING VIDEO SIGNAL
    '   GOSUB HEADER    ' LINE 3 RIGHT HAND SIDE TEST.
    '   ENDIF
    '   IF CURRENTMODE0=1 THEN
    '   GOSUB NOVIDEO   ' DISPLAYS NO VIDEO IF NO INCOMING SYNCHS
    '    ENDIF
    '    PAUSE 500            'I/2 SECOND DELAY
    '    TOGGLE HEARTBEAT     ' LED
        GOTO LOOPER           'DO IT FOREVER
    DISPLAYCHAR:
    WDATA = %0001011100000000 + STVCHAR
    ' bit 10 = red
    ' bit 09 = green
    ' bit 08 = blue
    ' 000 = black
    ' 001 = blue
    ' 010 = green
    ' 011 = cyan
    ' 100 = red
    ' 101 = magenta
    ' 110 = yellow
    ' 111 = white
    ' bit 7 = blink 1=enable 0=disable
        GOSUB SEND
    SETLINE:
    	WDATA = LINECOUNTER*256 + CHARCOUNTER
        GOSUB Send              'position cursor
    WasteTime:        ' WORKS WITH LESS NOPS
        pauseus 20    ' was 20 nops
    StartCommunication:
    	TVSCL = 1 'HIGH TVSCL
        GOSUB WasteTime
        CS0 = 0 'LOW CS0
        GOSUB WasteTime
    	TVSCL = 0 'LOW TVSCL
        GOSUB WasteTime
    StopCommunication:
        GOSUB WasteTime
        CS0 = 1 'HIGH CS0
        GOSUB WasteTime
    SendOne:
    	TVSDA = 1 'HIGH TVSDA
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    SendZero:
    	TVSDA = 0 'LOW TVSDA
        GOSUB WasteTime
    	TVSCL = 0 ' LOW TVSCL
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    OutByte:
    	FOR BITCOUNTER = 1 TO 16
        IF WDATA.15 = 1 THEN
        GOSUB SendOne
        GOSUB SendZero
        WDATA = WDATA << 1
    	NEXT BITCOUNTER
    Send:
    	GOSUB StartCommunication
    	GOSUB OutByte
    	GOSUB StopCommunication
    Init:     '    PAUSE 50 added - seems to improve reliability of init
        CS0 = 1 'HIGH CS0
    	WDATA = $3000  '%110000 00000000
        GOSUB Send ' Init STV5730
        PAUSE 50
    	WDATA = $3000
        GOSUB Send
        PAUSE 50
    	WDATA = $00DB  '%00000000 11011011
        GOSUB Send
        PAUSE 50
    	WDATA = $1000  '%00010000 00000000
        GOSUB Send
        PAUSE 50
    	WDATA = %0000000011001100
        GOSUB Send ' Init registers (point to register 12)
        PAUSE 50
    	WDATA = %0001000000000000   'NORMAL
    '  WDATA = %0001000011110000   '4 PIXELS HORIZ AND VERT
        GOSUB Send ' Zoom    ADDRESS 12
        PAUSE 50
    	WDATA = %0001001000000000
    '    	WDATA = %0001001000000100
             GOSUB Send ' Color    ADDRESS 13
             PAUSE 50
        WDATA=  %0001101011010100
                'CHANGE BIT 0 TO 1 FOR TEXT ONLY
        GOSUB Send ' Control    ADDRESS 14
    	WDATA = %0001001100001111
    ' was  WDATA = %0001 0111 1100 1111
        GOSUB Send ' Position    ADDRESS 15
    	WDATA = %0001000100101110 '$183E BIT 11 CHANGED TO 0  M4 = 0
        GOSUB Send ' Mode    ADDRESS 16  %0001100000111110
    	WDATA = $00C0   '%00000000 11000000
        GOSUB Send ' Set row attributes
    	FOR ICOUNT = 0 TO 10
    	 WDATA = %0001000010000001 '%00010000 11000100 was $10C4
      	' WDATA =%0001000010000111
         GOSUB Send
    	NEXT ICOUNT
    CLS:
        'character=$0B       'SPACE
         TEMP1=0   ' LINECOUNTER
         TEMP =0    'CHARCOUNTER
    loop2:
    	WDATA = 0  ' LINECOUNTER*256 + CHARCOUNTER   ADDRESS
        GOSUB Send
    LOOP3:    '                :CHARACTERS
    	WDATA = %0001011100001011  '     1011 0BH SPACECHARACTER
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
    	IF TEMP1 >= 11 THEN SCREENBLANK
        GOTO LOOP3
    SCREENBLANK:
    GETSTVCHAR:                  'CONVERT ASCII TO STV
        STVCHAR =$7F   ' FORCES CLOCK PICTURE IF ERROR
        LOOKDOWN ASCCHAR,["0123456789- ABCDEFGHIJKLMNOPQRSTUVWXYZ:./'abcdefghijklmnopqrstuvwxyz"],STVCHAR
    HEADER:
        LINECOUNTER=0      'SET START POSITION
        CHARCOUNTER=1      'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=0 TO 4
        READ CHARS2, ASCCHAR
        gosub GETSTVCHAR    'CONVERT ASCII TO STV
        GOSUB DISPLAYCHAR
        NEXT
        LINECOUNTER=10       'SET START POSITION
        GOSUB SETLINE
        ASCCHAR = "P"
        GOSUB DISPLAYCHAR
        ASCCHAR = "R"
        GOSUB DISPLAYCHAR
        ASCCHAR = "P"
        GOSUB DISPLAYCHAR
        ASCCHAR = "M"
        GOSUB DISPLAYCHAR
        ASCCHAR = " "
        GOSUB DISPLAYCHAR
        STVCHAR = PRPM DIG 3       '****** DIG VALUES ONLY
        GOSUB DISPLAYCHAR           'NEEDS TO BE STVCHAR !!
        STVCHAR = PRPM DIG 2
        GOSUB DISPLAYCHAR
        STVCHAR = PRPM DIG 1
        GOSUB DISPLAYCHAR
        STVCHAR = PRPM DIG 0
        GOSUB DISPLAYCHAR
    NOVIDEO:
        LINECOUNTER=5       'SET START POSITION
        CHARCOUNTER=4       'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=6 TO 23      ' FROM EEPROM DATA
        GOSUB DISPLAYCHAR
        NEXT
    TRYSYNCHS:
        PULSES=0
        COUNT SYNCH0,4,PULSES   '3MS SHOULD COUNT TO 2 OR 3
        IF PULSES > 0 THEN MIXED0
    FULL0:
        IF CURRENTMODE0=1 THEN RETURN
        WDATA=  %0000000011001110       'CONTROL REGISTER
        GOSUB SEND
        WDATA=  %0001101011010101
                'CHANGE BIT 0 TO 1 FOR TEXT ONLY       OTIGINAL
     '     WDATA=  %0001101111010100
        GOSUB SEND
    STAYHERE02:
        CURRENTMODE0=1
            GOSUB CLS
    GOBACK0:
    MIXED0:
        IF CURRENTMODE0=0 THEN RETURN
        GOSUB SEND
        GOSUB SEND
    STAYHERE01:
        CURRENTMODE0=0
        GOSUB CLS
        '----------------------debug fills screen with X------------------
    FILLSCREEN:
    loop2a:
        GOSUB Send
    LOOP3a:    '                :CHARACTERS 100011
    	WDATA = %0001011101100011  '     X CHARACTER
    '   WDATA = %0001011101110111
    '    if temp1 =0 then WDATA = %0001011101110111
        if temp1 =1 then WDATA = %0001000001100011
        if temp1 =2 then WDATA = %0001000101100011
        if temp1 =3 then WDATA = %0001001001100011
        if temp1 =4 then WDATA = %0001001101100011
        if temp1 =5 then WDATA = %0001010001100011
        if temp1 =6 then WDATA = %0001010101100011
        if temp1 =7 then WDATA = %0001011001100011
        if temp1 =8 then WDATA = %0001011101100011
        if temp1 >=9 then WDATA = %0001011100100011
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
    	IF TEMP1 >= 11 THEN SCREENBLANKA
        GOTO LOOP3A
    SCREENBLANKA:
    Thanks, Ed
    if temp1 =8 then WDATA = %0001011101100011 = white square
    if temp1 >=9 then WDATA = %0001011100100011 = X
    Also remember rows are 0-10 not 1 - 11
    Mar 2011
    Thanks Aerostar,
    Just another brain cramp on my part. As long as the background is blue then color squares appear. With video, only white squares. I keep searching the internet for a chip that will produce color with a video input and not a generated background. I cannot believe no one has or makes such a chip!
    Best, Ed
