From the depths of the old files I found this -
On the STV PDF, it shows Circuitry around pins 5 and 6 I incorporated this, but I see the schematic above does not, I think as long as you have a good smoothed 5 volt power supply with good decoupling caps, there should not be a problem. However he does not show decoupling caps on his 9-12V DC circuit, 100N/220N should be in parallel with his 47uF caps and be close to the regulator.
On my board R3 (3k3) not fitted, My board, and the program you have uses CSYNC to work out the switching of modes, from what I remember I found odd problems using the MUTE, but cannot remember exactly what ! I think it did not always change the level when it should have or took a while to change.
Different coloured characters, It is in
DISPLAYCHAR:
WDATA = %0001011100000000 + STVCHAR
Bits 10,9, and 8 internal ram buffer, page 7 of my PDF, according to the STV data control the colour of the character.
You will have to try that when you get your system running correctly
