And to prove it really does work - see below - wobbly camera as it was my phone and had to have the other hand to make the connection to the top board at the same time.
Part of the PCB lay out was on the net way back 2003 or earlier, done with the free version of Protel as was then, I modified it to fit what I wanted and had the boards made as it was a commercial job. The text was only used as white but should be able to change using the color register I think.
If I get chance I will see if I still have the board layout - it will take a day or more - have to dig in to old backups etc and when I get the time.
That really looks really great!
Thank you for the files too! My programmer is a PICSTART PLUS and that should not make any difference. Two questions, how did you wire your STV5730A? Second question, have you tried to have the text be a color? Again, what a great job!!!
