A little HELP!!
Results 1 to 40 of 77
Thread: A little HELP!!
    Default Re: A little HELP!!
    Have just glanced at your code, first thing I noticed was
    You have 2 declarations for Port B.6 this may well be your problem
    TVSDA VAR PORTB.4 '0 OUTPUT pin 11 stv was b.1
    CS0 VAR PORTB.6 '0 OUTPUT pin 13 stv was b.0 <<<<<<<<<<<<<<<<<<<<<<<<<
    TVSCL VAR PORTB.5 '0 OUTPUT pin 12 stv was b.5
    SYNCH0 VAR PORTB.7 '1 'INPUT to pin 7 stvchip was b.2
    HEARTBEAT VAR PORTB.6 'OUTPUT 0 led was b.6 <<<<<<<<<<<<<<<<<<<<<<<<<<<<
    I will have another look tomorrow as it is bedtime over here (UK) and I am tired.
    Thought.... as you are only using digital ports PORT B you do not need the include file.
    The file just makes all Analog ports digital - it works fine on 628a and others BUT may not work on newer chips, as I mostly use these or similar.
    Last edited by aerostar; - 23rd June 2017 at 00:20. Reason: Added info re Alldigital
    Mar 2011
    Los Angeles, California
    I will try that a little later. Right now the program freezes right after the TRISB statement at the Pause 500. Comment out the Pause 500 at it stops at the High Heartbeat! I am so confused!
    I have got the monitor that does NTSC, changing the appropriate bit 8 in the register 14 and with the 14.318 xtal in the STV board, I get a picture with readable text, see below.
    However the display is not in the correct place and there is no colour. Further investigation needed!!
    It sort of looks like the timing is wrong somewhere probably another setting needs to be changed.
    Mar 2011
    Looks Great! I am still stuck with my program freezing right after the TRISB statement at the Pause 500. Comment out the Pause 500 at it stops at the High Heartbeat! I am so confused!
    News
    I have NTSC display full colour and in the correct position. Problem was low voltage on my STV board, when that was fixed it worked straight away.
    Code attached
    Program your 628a with the hex code, if it works on your 628A then you have a compiler prob or something, if it does not work you may have a naff 628a.
    Also I compile with Picbasic Pro Ver 2.60C - I think you compile using MPLAB, not sure of your PB version, try compiling the 628a code with the PBP compiler.
    heartbeat led remarked out
    cmcon added in, but not needed as you are not using port A
    TRIS B changed to reflect your ports use.
    '*  Name    : STV-SYNCHS RELEASE                          *
    '*  Author  : BOB LEGGETT                                       *
    '*  Notice  : Copyright (c) 2009                                *
    '*  Date    : around 2009 or so rehashed now '17         *
    '*  Notes   :   VIDEO IDENT                                *
    '   WORKS USES SYNC FOR SWITCHING BETWEEN MIXED AND FULL TEXT MODE
    '   GOING FROM VID IN TO TEXT AND BACK TO VID IN
    @ device PIC16f628a,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON
        define  OSC 20
    'TV CHIP CONNECTIONS
       '16f628a  ED definitions
     'HEARTBEAT      VAR PORTB.6           'OUTPUT 0  led was b.6
    '16f628a
    '	  TVSDA     		VAR PORTB.1    '0     OUTPUT  pin 11 stv
    ' 	CS0     		VAR PORTB.0 '0       OUTPUT pin 13 stv
    '	TVSCL     		VAR PORTB.5    '0    OUTPUT  pin 12 stv
    '   SYNCH0          VAR PORTB.2 '1       'INPUT    to pin 7 stvchip
    '   HEARTBEAT        VAR PORTB.6     'OUTPUT 0  led
        ZOOMREG         CON %0000000011001100       ' 12 ZOOM REGISTER
        COLREG          CON %0000000011001101       ' 13 COLOUR REGISTER
        CONREG          CON %0000000011001110       ' 14 CONTROL REGISTER
        POSREG          CON %0000000011001111       ' 15 POSITION REGISTER
        MODEREG         CON %0000000011010000       ' 16 MODE REGISTER
    	ICOUNT  		VAR BYTE
    	BITCOUNTER 	VAR BYTE
    	WDATA   		VAR WORD
    	CHARCOUNTER	VAR BYTE '
    	LINECOUNTER	VAR BYTE '
         STVCHAR VAR BYTE
        ASCCHAR VAR BYTE
        CHARS VAR BYTE
        CHARS2 VAR BYTE
        TEMP    VAR BYTE
        TEMP1   VAR BYTE
         COUNTER VAR BYTE
         PULSES VAR BYTE
        CURRENTMODE0 VAR BYTE
    '    TOPLEFT          CON 0
    '    TOPMIDDLE       CON 5
    '    TOPRIGHT        CON 10
    '    BOTLEFT         CON 2560    '10*256
    '    BOTMIDDLE       CON 2565 '(10*256)+ 5
    '    BOTRIGHT        CON 2570 '(10*256)+ 10
        DATA @0,"NTSC ",$FF,"NO SYNCHS RECEIVED",$FF
    '628
    '  TRISB=%10011100
      TRISB = %10001111
      CMCON=7
        PAUSE 500
    '    HIGH HEARTBEAT
    	GOSUB Init
        PAUSE 500
    	GOSUB Init
        CURRENTMODE0=255         ' FORCES TRYSYNCHS TO SET MODE FIRST TIME
    Demo:
    CHARCOUNTER = 0
    	LINECOUNTER = 0
    '    CURRENTMODE0 = 0     '0 = MIXED 1 = TEXT
        gosub CLS
        GOSUB TRYSYNCHS      '==================================
        TEMP = 0
    LOOPER:
        GOSUB HEADER   ' LINE 3 RIGHT HAND SIDE TEST.
        IF CURRENTMODE0=1 THEN
        GOSUB NOVIDEO   ' DISPLAYS NO VIDEO IF NO INCOMING SYNCHS
    '    PAUSE 500            'I/2 SECOND DELAY
    '    TOGGLE HEARTBEAT      ' LED
        GOTO LOOPER          'DO IT FOREVER
    DISPLAYCHAR:
        WDATA = %0001011100000000 + STVCHAR
        GOSUB SEND
    SETLINE:
    	WDATA = LINECOUNTER*256 + CHARCOUNTER
        GOSUB Send              'position cursor
    WasteTime:        ' WORKS WITH LESS NOPS
        pauseus 20    ' was 20 nops
    StartCommunication:
    	TVSCL = 1 'HIGH TVSCL
        GOSUB WasteTime
        CS0 = 0 'LOW CS0
        GOSUB WasteTime
    	TVSCL = 0 'LOW TVSCL
        GOSUB WasteTime
    StopCommunication:
        GOSUB WasteTime
        CS0 = 1 'HIGH CS0
        GOSUB WasteTime
    SendOne:
    	TVSDA = 1 'HIGH TVSDA
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    SendZero:
    	TVSDA = 0 'LOW TVSDA
        GOSUB WasteTime
    	TVSCL = 0 ' LOW TVSCL
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    OutByte:
    	FOR BITCOUNTER = 1 TO 16
    	 IF WDATA.15 = 1 THEN
    	  GOSUB SendOne
    	  GOSUB SendZero
    	 WDATA = WDATA << 1
    	NEXT BITCOUNTER
    Send:
    	GOSUB StartCommunication
    	GOSUB OutByte
    	GOSUB StopCommunication
    Init:     '    PAUSE 50 added - seems to improve reliability of init
        CS0 = 1 'HIGH CS0
    	WDATA = $3000  '%110000 00000000
        GOSUB Send ' Init STV5730
        PAUSE 50
    	WDATA = $3000
        GOSUB Send
        PAUSE 50
    	WDATA = $00DB  '%00000000 11011011
        GOSUB Send
        PAUSE 50
    	WDATA = $1000  '%00010000 00000000
        GOSUB Send
        PAUSE 50
    	WDATA = %0000000011001100
        GOSUB Send ' Init registers (point to register 12)
        PAUSE 50
    	WDATA = %0001000000000000   'NORMAL
    '  WDATA = %0001000011110000   '4 PIXELS HORIZ AND VERT
        GOSUB Send ' Zoom    ADDRESS 12
        PAUSE 50
    	WDATA = %0001001000000000
    '    	WDATA = %0001001000000100
             GOSUB Send ' Color    ADDRESS 13
             PAUSE 50
         WDATA=  %0001101011010100    'BIT 8 = 0 FOR NTSC
                'CHANGE BIT 0 TO 1 FOR TEXT ONLY
        GOSUB Send ' Control    ADDRESS 14
    	WDATA = %0001011111001111
        GOSUB Send ' Position    ADDRESS 15
    	WDATA = %0001000000101110 '$183E BIT 11 CHANGED TO 0  M4 = 0
           GOSUB Send ' Mode    ADDRESS 16  %0001100000111110
    	WDATA = $00C0   '%00000000 11000000
        GOSUB Send ' Set row attributes
    	FOR ICOUNT = 0 TO 10
    	 WDATA = $10C4 '%00010000 11000100
      	' WDATA =%0001000010000111
         GOSUB Send
    	NEXT ICOUNT
    CLS:
        'character=$0B       'SPACE
         TEMP1=0   ' LINECOUNTER
         TEMP =0    'CHARCOUNTER
    loop2:
    	WDATA = 0  ' LINECOUNTER*256 + CHARCOUNTER   ADDRESS
        GOSUB Send
    LOOP3:    '                :CHARACTERS
    	WDATA = %0001011100001011  '     1011 0BH SPACECHARACTER
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
    	IF TEMP1 >= 11 THEN SCREENBLANK
        GOTO LOOP3
    SCREENBLANK:
    GETSTVCHAR:                  'CONVERT ASCII TO STV
            STVCHAR =$7F   ' FORCES CLOCK PICTURE IF ERROR
           LOOKDOWN ASCCHAR,["0123456789- ABCDEFGHIJKLMNOPQRSTUVWXYZ:./'abcdefghijklmnopqrstuvwxyz"],STVCHAR
    HEADER:
        LINECOUNTER=2       'SET START POSITION
        CHARCOUNTER=23      'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=0 TO 4
        READ CHARS2, ASCCHAR
        gosub GETSTVCHAR    'CONVERT ASCII TO STV
        GOSUB DISPLAYCHAR
        NEXT
    NOVIDEO:
        LINECOUNTER=5       'SET START POSITION
        CHARCOUNTER=4       'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=6 TO 23      ' FROM EEPROM DATA
        GOSUB DISPLAYCHAR
        NEXT
    TRYSYNCHS:
        PULSES=0
        COUNT SYNCH0,4,PULSES   '3MS SHOULD COUNT TO 2 OR 3
        IF PULSES > 0 THEN MIXED0
    FULL0:
        IF CURRENTMODE0=1 THEN RETURN
        WDATA=  %0000000011001110       'CONTROL REGISTER
        GOSUB SEND
        WDATA=  %0001101011010101   'NTSC
    '        WDATA=  %0001101011010101   'NTSC     BIT 8 = 0
                'CHANGE BIT 0 TO 1 FOR TEXT ONLY       OTIGINAL
     '     WDATA=  %0001101111010100
        GOSUB SEND
    STAYHERE02:
        CURRENTMODE0=1
            GOSUB CLS
    GOBACK0:
    MIXED0:
        IF CURRENTMODE0=0 THEN RETURN
        GOSUB SEND
        WDATA=  %0001100111010100    'ntsc
    '    WDATA=  %0001101011010100     'NTSC   BIT 8 = 0
        GOSUB SEND
    STAYHERE01:
        CURRENTMODE0=0
        GOSUB CLS
    HEX code for programmer compiled from above code
    :100000006C28B400841780048413FA30A6000030F2
    :10001000A7005120A00AA50AA201A30100083405E7
    :10002000A600640000083405A7002606270534064C
    :100030000319A20A0319A30A2708A600A403031997
    :10004000A5030319A00B11282208672883161C1486
    :100050001A0883169B0A6728A301A200FF30A20793
    :10006000031CA307031C67280330A100E6303A20D5
    :100070002E28A101FC3EA000A109031C4528FF3049
    :100080000000A00703184028A0076400A10F3F2824
    :1000900008000310A00DA10DFF3E031849282008F9
    :1000A00067281030A800A101A001A70CA60C031C12
    :1000B0005F282208A00723080318230FA107A10C1B
    :1000C000A00CA50CA40CA80B5528240867288313A2
    :1000D000031383126400080083168F308600831296
    :1000E00007309F000130A300F4302D20DE200130C6
    :1000F000A300F4302D20DE20FF30C200BE01C40179
    :100100002C21CE21C701A12164004208013C031D1E
    :100110008A28B721CE21832800304607BA0017303D
    :100120000318013EBB00DA2008004408A600A7011E
    :10013000A2010130A3005120B8002508B9003E08F3
    :100140003807BA0039080318013EBB00DA2008005E
    :100150001430392008008616A8200613A82086121D
    :10016000A82008008616A8200617A8200800061652
    :10017000A8208612A8208616A82008000612A8200B
    :100180008612A8208616A8200616A820080001308E
    :10019000BD00640011303D020318D9286400BB1F64
    :1001A000D328B720D428BE200310BA0DBB0DBD0F35
    :1001B000C9280800AB20C720B22008008616061602
    :1001C0000617BA013030BB00DA2032302C20BA01D9
    :1001D0003030BB00DA2032302C20DB30BA00BB01DB
    :1001E000DA2032302C20BA011030BB00DA20323055
    :1001F0002C20CC30BA00BB01DA2032302C20BA01DE
    :100200001030BB00DA2032302C20BA011230BB0093
    :10021000DA2032302C20D430BA001A30BB00DA2079
    :10022000CF30BA001730BB00DA202E30BA001030C1
    :10023000BB00DA20C030BA00BB01DA20C301640081
    :100240000B30430203182B29C430BA001030BB0016
    :10025000DA20C30F1F290800C801C701BA01BB017A
    :10026000DA200B30BA001730BB00DA20C70A64006E
    :100270001C304702031C3E29C701C80A64000B302A
    :10028000480203184429312908007F30C600FF3096
    :10029000A200A20A2208433C031CA02955213C02CB
    :1002A000031D49292208C600A02901308A0022081E
    :1002B0005C3E03188A0A82003034313432343334DD
    :1002C0003434353436343734383439342D342034FA
    :1002D000413442344334443445344634473448345A
    :1002E00049344A344B344C344D344E344F3450340A
    :1002F00051345234533454345534563457345834BA
    :1003000059345A343A342E342F3427346134623419
    :1003100063346434653466346734683469346A3409
    :100320006B346C346D346E346F34703471347234B9
    :1003300073347434753476347734783479347A3469
    :1003400008000230C4001730BE009520C0016400D0
    :10035000053040020318B629400883169B0083121B
    :100360002620BC0045218C20C00FA729080005309D
    :10037000C4000430BE0095200630C0006400183070
    :1003800040020318CD29400883169B0083122620C3
    :10039000BC0045218C20C00FBE290800C5010430D7
    :1003A000A200A3010630840080300120C500640053
    :1003B000013045020318EF2964004208013C031D87
    :1003C000E2290800CE30BA00BB01DA20D530BA00ED
    :1003D0001A30BB00DA200130C2002C210800640072
    :1003E0004208003C031DF5290800CE30BA00BB01CD
    :1003F000DA20D430BA001930BB00DA20C2012C2137
    :020400000800F2
    :02400E00663F0B
    :104200004E005400530043002000FF004E004F00BA
    :104210002000530059004E00430048005300200086
    :104220005200450043004500490056004500440047
    :02423000FF008D
    :00000001FF
    Mar 2011
    Hi Aerostar!
    Thank you, Thank you, Thank you! I do not know how to save your hex code to a file? Second the statement "@ device PIC16f628a,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON" does not allow me to compile the program, had to change it to a config. I am using Micro Code Studio Plus 5.0.0.5 PBPX 3.1.0.4 and MPLAB IDE V8.92. I did try 4 different 16F628A's and end up with the same results. I do have pin 4 of the 16F628A tied to +5v through a 4.7k resistor as i understand this to be the MCLR for the 16F628A. I believe our code is identical except for the config statement as I added the config to your code so it would compile. Not sure what else to change, maybe if you have time you can compile my version and see if it will work? I did order some more STV5730's which should be here any day now.
    ' @ device PIC16f628a,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON
        __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
        define  OSC 20
     SYNCH0         VAR PORTB.7    '1     INPUT    to pin 7 stvchip was b.2
     'HEARTBEAT      VAR PORTB.6          OUTPUT 0  led was b.6
    '16f628a
    '   SYNCH0          VAR PORTB.2    '1    INPUT    to pin 7 stvchip
    '   HEARTBEAT       VAR PORTB.6    '     OUTPUT 0  led
    	ICOUNT  		VAR BYTE
    	BITCOUNTER 	VAR BYTE
    	WDATA   		VAR WORD
         STVCHAR VAR BYTE
        ASCCHAR VAR BYTE
        CHARS VAR BYTE
        CHARS2 VAR BYTE
        TEMP    VAR BYTE
        TEMP1   VAR BYTE
         COUNTER VAR BYTE
         PULSES VAR BYTE
    '    TOPLEFT          CON 0
    '    TOPMIDDLE       CON 5
    '    TOPRIGHT        CON 10
    '628
    '  TRISB=%10011100
      TRISB = %10001111
      CMCON=7
        PAUSE 500
    '    HIGH HEARTBEAT
    	GOSUB Init
        PAUSE 500
    	GOSUB Init
    Demo:
    CHARCOUNTER = 0
    	LINECOUNTER = 0
        gosub CLS
        TEMP = 0
    LOOPER:
    DISPLAYCHAR:
        GOSUB SEND
    SETLINE:
    StartCommunication:
        GOSUB WasteTime
        CS0 = 0 'LOW CS0
        GOSUB WasteTime
        GOSUB WasteTime
    StopCommunication:
        GOSUB WasteTime
        CS0 = 1 'HIGH CS0
        GOSUB WasteTime
    SendOne:
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    SendZero:
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    OutByte:
    	  GOSUB SendOne
    	  GOSUB SendZero
    	 WDATA = WDATA << 1
    	NEXT BITCOUNTER
    Send:
    	GOSUB OutByte
        CS0 = 1 'HIGH CS0
        PAUSE 50
    	WDATA = $3000
        GOSUB Send
        PAUSE 50
        GOSUB Send
        PAUSE 50
        GOSUB Send
        PAUSE 50
        PAUSE 50
        PAUSE 50
             PAUSE 50
         GOSUB Send
    	NEXT ICOUNT
    CLS:
    loop2:
        GOSUB Send
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
        GOTO LOOP3
    SCREENBLANK:
    HEADER:
        GOSUB SETLINE
        FOR CHARS2=0 TO 4
        GOSUB DISPLAYCHAR
        NEXT
    NOVIDEO:
        GOSUB SETLINE
        GOSUB DISPLAYCHAR
        NEXT
    TRYSYNCHS:
        PULSES=0
    FULL0:
        GOSUB SEND
        GOSUB SEND
    STAYHERE02:
        CURRENTMODE0=1
            GOSUB CLS
    GOBACK0:
    MIXED0:
        GOSUB SEND
        GOSUB SEND
    STAYHERE01:
        CURRENTMODE0=0
        GOSUB CLS
    Many thanks, Ed
    P.S. If you wish to e-mail me files my e-mail is [email protected]
    You use highlite text, copy and paste as you would in word processing.
    To save the hex code ,put mouse at top left of hexcode, the pointer will change to something that looks like a capital I,the vertical part should just touch the left side of the colon on the top line, single left mouse click, use the slide bar on the right of the hex code to scroll down to the bottom of the code, move the mouse pounter to the last character, so the vertical part of the I just touches the right hand side of the F, hold the shift button down and then single left mouse click that will highlite the code, then Control C that will copy all the highlited text, now run notepad, right click on blank area and select paste, the hex code will appear, now save this as whatever name you wish with the extension as .hex. You can then load it into your programmer.
    I will look at trying your code tomorrow sometime.
    I would suggest you edit and mask your email as it will get picked up by the spam bots - write it as edcannady at earthlink dot net
