A little HELP!!
Results 1 to 40 of 77
Thread: A little HELP!!
    Default Re: A little HELP!!
    Looks likely I can run a partial test on NTSC, I have found the appropriate crystal deep in the odd box, and I have the possible loan of a multi monitor, it is rather old but if it still works it will do NTSC.
    I have found the original picbasic files on the web, and that compiles fine for 16F628a. The only thing I have to change are the port numbers to suit my pic/sstv board, all operations will be unchanged.
    I do not have a NTSC source, so it would not be a full test, but if text appears, then that should at least prove the NTSC side is working.
    It will be a few days before I get the chance to do this.
    In the meantime please post if you get your board working on NTSC.
    Mar 2011
    Los Angeles, California
    Hi Aerostar!
    I cannot tell how much I appreciate what you are doing! The same as you I have to make some port changes to accommodate wiring. I think I set the TRISB settings correctly and well as the register changes you recommended. This is probably going to sound strange and when I run the code it gets stuck (stops) at "Pause 500"! not sure why?
    '*  Name    : STV-SYNCHS RELEASE                          *
    '*  Author  : BOB LEGGETT                                       *
    '*  Notice  : Copyright (c) 2009                                *
    '*  Date    : around 2009 or so rehashed now '17         *
    '*  Notes   :   VIDEO IDENT                                *
    '   WORKS USES SYNC FOR SWITCHING BETWEEN MIXED AND FULL TEXT MODE
    '   GOING FROM VID IN TO TEXT AND BACK TO VID IN
    INCLUDE "ALLDIGITAL.pbp"
    define  OSC 20
        __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    'TV CHIP CONNECTIONS
     '16f628a
     TVSDA     		VAR PORTB.4    '0     OUTPUT  pin 11 stv was b.1
     CS0     		VAR PORTB.6    '0     OUTPUT pin 13 stv was b.0
     TVSCL     		VAR PORTB.5    '0     OUTPUT  pin 12 stv was b.5
     SYNCH0         VAR PORTB.7    '1     'INPUT    to pin 7 stvchip was b.2
     HEARTBEAT      VAR PORTB.6           'OUTPUT 0  led was b.6
        ZOOMREG         CON %0000000011001100       ' 12 ZOOM REGISTER
        COLREG          CON %0000000011001101       ' 13 COLOUR REGISTER
        CONREG          CON %0000000011001110       ' 14 CONTROL REGISTER
        POSREG          CON %0000000011001111       ' 15 POSITION REGISTER
        MODEREG         CON %0000000011010000       ' 16 MODE REGISTER
    	ICOUNT  		VAR BYTE
    	BITCOUNTER 	    VAR BYTE
    	WDATA   		VAR WORD
    	CHARCOUNTER	    VAR BYTE '
    	LINECOUNTER	    VAR BYTE '
        STVCHAR         VAR BYTE
        ASCCHAR         VAR BYTE
        CHARS           VAR BYTE
        CHARS2          VAR BYTE
        TEMP            VAR BYTE
        TEMP1           VAR BYTE
        COUNTER         VAR BYTE
        PULSES          VAR BYTE
        CURRENTMODE0    VAR BYTE
    '    TOPLEFT         CON 0
    '    TOPMIDDLE       CON 5
    '    TOPRIGHT        CON 10
    '    BOTLEFT         CON 2560    '10*256
    '    BOTMIDDLE       CON 2565 '(10*256)+ 5
    '    BOTRIGHT        CON 2570 '(10*256)+ 10
        DATA @0,"TEST.",$FF,"NO SYNCHS RECEIVED",$FF
    '628
      TRISB=%10000100
        PAUSE 500
        HIGH HEARTBEAT
    	GOSUB Init
        PAUSE 500
    	GOSUB Init
        CURRENTMODE0=255         ' FORCES TRYSYNCHS TO SET MODE FIRST TIME
    Demo:
        CHARCOUNTER = 0
    	LINECOUNTER = 0
    '   CURRENTMODE0 = 0     '0 = MIXED 1 = TEXT
        gosub CLS
        GOSUB TRYSYNCHS      '==================================
        TEMP = 0
    LOOPER:
        GOSUB HEADER    ' LINE 3 RIGHT HAND SIDE TEST.
        IF CURRENTMODE0=1 THEN
        GOSUB NOVIDEO   ' DISPLAYS NO VIDEO IF NO INCOMING SYNCHS
        PAUSE 500            'I/2 SECOND DELAY
        TOGGLE HEARTBEAT      ' LED
        GOTO LOOPER          'DO IT FOREVER
    DISPLAYCHAR:
        WDATA = %0001011100000000 + STVCHAR
        GOSUB SEND
    SETLINE:
    	WDATA = LINECOUNTER*256 + CHARCOUNTER
        GOSUB Send              'position cursor
    WasteTime:        ' WORKS WITH LESS NOPS
        pauseus 20    ' was 20 nops
    StartCommunication:
    	TVSCL = 1 'HIGH TVSCL
        GOSUB WasteTime
        CS0 = 0 'LOW CS0
        GOSUB WasteTime
    	TVSCL = 0 'LOW TVSCL
        GOSUB WasteTime
    StopCommunication:
        GOSUB WasteTime
        CS0 = 1 'HIGH CS0
        GOSUB WasteTime
    SendOne:
    	TVSDA = 1 'HIGH TVSDA
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    SendZero:
    	TVSDA = 0 'LOW TVSDA
        GOSUB WasteTime
    	TVSCL = 0 ' LOW TVSCL
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    OutByte:
    	FOR   BITCOUNTER = 1 TO 16
        IF    WDATA.15 = 1 THEN
        GOSUB SendOne
        GOSUB SendZero
              WDATA = WDATA << 1
    	NEXT  BITCOUNTER
    Send:
    	GOSUB StartCommunication
    	GOSUB OutByte
    	GOSUB StopCommunication
    Init:     '    PAUSE 50 added - seems to improve reliability of init
        CS0   = 1 'HIGH CS0
    	WDATA = $3000  '%110000 00000000
        GOSUB Send ' Init STV5730
        PAUSE 50
    	WDATA = $3000
        GOSUB Send
        PAUSE 50
    	WDATA = $00DB  '%00000000 11011011
        GOSUB Send
        PAUSE 50
    	WDATA = $1000  '%00010000 00000000
        GOSUB Send
        PAUSE 50
    	WDATA = %0000000011001100
        GOSUB Send ' Init registers (point to register 12)
        PAUSE 50
    	WDATA = %0001000000000000   'NORMAL
    '   WDATA = %0001000011110000   '4 PIXELS HORIZ AND VERT
        GOSUB Send ' Zoom    ADDRESS 12
        PAUSE 50
    	WDATA = %0001001000000000
    '   WDATA = %0001001000000100
        GOSUB Send ' Color    ADDRESS 13
        PAUSE 50
        WDATA=  %0001101011010100
                'CHANGE BIT 0 TO 1 FOR TEXT ONLY
        GOSUB Send ' Control    ADDRESS 14
    	WDATA = %0001011111001111
        GOSUB Send ' Position    ADDRESS 15
    	WDATA = %0001000100101110 '$183E BIT 11 CHANGED TO 0  M4 = 0
        GOSUB Send ' Mode    ADDRESS 16  %0001100000111110
    	WDATA = $00C0   '%00000000 11000000
        GOSUB Send      ' Set row attributes
    	FOR ICOUNT = 0 TO 10
        WDATA = $10C4 '%00010000 11000100
                      ' WDATA =%0001000010000111
        GOSUB Send
    	NEXT ICOUNT
    CLS:
        'character=$0B       'SPACE
         TEMP1=0   ' LINECOUNTER
         TEMP =0    'CHARCOUNTER
    loop2:
    	WDATA = 0  ' LINECOUNTER*256 + CHARCOUNTER   ADDRESS
        GOSUB Send
    LOOP3:    '                :CHARACTERS
    	WDATA = %0001011100001011  '     1011 0BH SPACECHARACTER
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
    	IF TEMP1 >= 11 THEN SCREENBLANK
        GOTO LOOP3
    SCREENBLANK:
    GETSTVCHAR:                  'CONVERT ASCII TO STV
        STVCHAR =$7F   ' FORCES CLOCK PICTURE IF ERROR
        LOOKDOWN ASCCHAR,["0123456789- ABCDEFGHIJKLMNOPQRSTUVWXYZ:./'abcdefghijklmnopqrstuvwxyz"],STVCHAR
    HEADER:
        LINECOUNTER=2       'SET START POSITION
        CHARCOUNTER=23      'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=0 TO 4
        READ CHARS2, ASCCHAR
        gosub GETSTVCHAR    'CONVERT ASCII TO STV
        GOSUB DISPLAYCHAR
        NEXT
    NOVIDEO:
        LINECOUNTER=5       'SET START POSITION
        CHARCOUNTER=4       'SET CURSOR POSITION
        GOSUB SETLINE
        FOR CHARS2=6 TO 23      ' FROM EEPROM DATA
        GOSUB DISPLAYCHAR
        NEXT
    TRYSYNCHS:
        PULSES=0
        COUNT SYNCH0,4,PULSES   '3MS SHOULD COUNT TO 2 OR 3
        IF PULSES > 0 THEN MIXED0
    FULL0:
        IF CURRENTMODE0=1 THEN RETURN
        WDATA=  %0000000011001110       'CONTROL REGISTER
        GOSUB SEND
        WDATA=  %0001101011010101 ' was 0001101111010101
       'CHANGE BIT 0 TO 1 FOR TEXT ONLY       OTIGINAL
       'WDATA=  %0001101111010100
        GOSUB SEND
    STAYHERE02:
        CURRENTMODE0=1
        GOSUB CLS
    GOBACK0:
    MIXED0:
        IF CURRENTMODE0=0 THEN RETURN
        GOSUB SEND
        WDATA=  %0001101011010101  'was 0001101111010100
        GOSUB SEND
    STAYHERE01:
        CURRENTMODE0=0
        GOSUB CLS
    I hope I pasted the code correctly this time!!!
    Best, Ed
    Have just glanced at your code, first thing I noticed was
    You have 2 declarations for Port B.6 this may well be your problem
    CS0 VAR PORTB.6 '0 OUTPUT pin 13 stv was b.0 <<<<<<<<<<<<<<<<<<<<<<<<<
    HEARTBEAT VAR PORTB.6 'OUTPUT 0 led was b.6 <<<<<<<<<<<<<<<<<<<<<<<<<<<<
    I will have another look tomorrow as it is bedtime over here (UK) and I am tired.
    Thought.... as you are only using digital ports PORT B you do not need the include file.
    The file just makes all Analog ports digital - it works fine on 628a and others BUT may not work on newer chips, as I mostly use these or similar.
    Last edited by aerostar; - 23rd June 2017 at 00:20. Reason: Added info re Alldigital
    Mar 2011
    I will try that a little later. Right now the program freezes right after the TRISB statement at the Pause 500. Comment out the Pause 500 at it stops at the High Heartbeat! I am so confused!
    I have got the monitor that does NTSC, changing the appropriate bit 8 in the register 14 and with the 14.318 xtal in the STV board, I get a picture with readable text, see below.
    However the display is not in the correct place and there is no colour. Further investigation needed!!
    It sort of looks like the timing is wrong somewhere probably another setting needs to be changed.
    Mar 2011
    Looks Great! I am still stuck with my program freezing right after the TRISB statement at the Pause 500. Comment out the Pause 500 at it stops at the High Heartbeat! I am so confused!
    News
    I have NTSC display full colour and in the correct position. Problem was low voltage on my STV board, when that was fixed it worked straight away.
    Code attached
    Program your 628a with the hex code, if it works on your 628A then you have a compiler prob or something, if it does not work you may have a naff 628a.
    Also I compile with Picbasic Pro Ver 2.60C - I think you compile using MPLAB, not sure of your PB version, try compiling the 628a code with the PBP compiler.
    heartbeat led remarked out
    cmcon added in, but not needed as you are not using port A
    TRIS B changed to reflect your ports use.
    @ device PIC16f628a,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON
        define  OSC 20
       '16f628a  ED definitions
     'HEARTBEAT      VAR PORTB.6           'OUTPUT 0  led was b.6
    '16f628a
    '	  TVSDA     		VAR PORTB.1    '0     OUTPUT  pin 11 stv
    ' 	CS0     		VAR PORTB.0 '0       OUTPUT pin 13 stv
    '	TVSCL     		VAR PORTB.5    '0    OUTPUT  pin 12 stv
    '   SYNCH0          VAR PORTB.2 '1       'INPUT    to pin 7 stvchip
    '   HEARTBEAT        VAR PORTB.6     'OUTPUT 0  led
    	ICOUNT  		VAR BYTE
    	BITCOUNTER 	VAR BYTE
    	WDATA   		VAR WORD
         STVCHAR VAR BYTE
        ASCCHAR VAR BYTE
        CHARS VAR BYTE
        CHARS2 VAR BYTE
        TEMP    VAR BYTE
        TEMP1   VAR BYTE
         COUNTER VAR BYTE
         PULSES VAR BYTE
    '    TOPLEFT          CON 0
    '    TOPMIDDLE       CON 5
    '    TOPRIGHT        CON 10
        DATA @0,"NTSC ",$FF,"NO SYNCHS RECEIVED",$FF
    '628
    '  TRISB=%10011100
      TRISB = %10001111
      CMCON=7
        PAUSE 500
    '    HIGH HEARTBEAT
    	GOSUB Init
        PAUSE 500
    	GOSUB Init
    Demo:
    CHARCOUNTER = 0
    	LINECOUNTER = 0
        gosub CLS
        TEMP = 0
    LOOPER:
    '    PAUSE 500            'I/2 SECOND DELAY
    '    TOGGLE HEARTBEAT      ' LED
    DISPLAYCHAR:
        GOSUB SEND
    SETLINE:
    StartCommunication:
        GOSUB WasteTime
        CS0 = 0 'LOW CS0
        GOSUB WasteTime
        GOSUB WasteTime
    StopCommunication:
        GOSUB WasteTime
        CS0 = 1 'HIGH CS0
        GOSUB WasteTime
    SendOne:
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    SendZero:
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
        GOSUB WasteTime
    OutByte:
    	  GOSUB SendOne
    	  GOSUB SendZero
    	 WDATA = WDATA << 1
    	NEXT BITCOUNTER
    Send:
    	GOSUB OutByte
        CS0 = 1 'HIGH CS0
        PAUSE 50
    	WDATA = $3000
        GOSUB Send
        PAUSE 50
        GOSUB Send
        PAUSE 50
        GOSUB Send
        PAUSE 50
        PAUSE 50
        PAUSE 50
             PAUSE 50
         WDATA=  %0001101011010100    'BIT 8 = 0 FOR NTSC
    	WDATA = %0001000000101110 '$183E BIT 11 CHANGED TO 0  M4 = 0
         GOSUB Send
    	NEXT ICOUNT
    CLS:
    loop2:
        GOSUB Send
        GOSUB Send
    	TEMP = TEMP + 1
    	IF TEMP >= 28 THEN
        TEMP = 0
        TEMP1=TEMP1 + 1
        GOTO LOOP3
    SCREENBLANK:
    HEADER:
        GOSUB SETLINE
        FOR CHARS2=0 TO 4
        GOSUB DISPLAYCHAR
        NEXT
    NOVIDEO:
        GOSUB SETLINE
        GOSUB DISPLAYCHAR
        NEXT
    TRYSYNCHS:
        PULSES=0
    FULL0:
        GOSUB SEND
        WDATA=  %0001101011010101   'NTSC
    '        WDATA=  %0001101011010101   'NTSC     BIT 8 = 0
     '     WDATA=  %0001101111010100
        GOSUB SEND
    STAYHERE02:
        CURRENTMODE0=1
            GOSUB CLS
    GOBACK0:
    MIXED0:
        GOSUB SEND
        WDATA=  %0001100111010100    'ntsc
    '    WDATA=  %0001101011010100     'NTSC   BIT 8 = 0
        GOSUB SEND
    STAYHERE01:
        CURRENTMODE0=0
        GOSUB CLS
    HEX code for programmer compiled from above code
    :100000006C28B400841780048413FA30A6000030F2
    :10001000A7005120A00AA50AA201A30100083405E7
    :10002000A600640000083405A7002606270534064C
    :100030000319A20A0319A30A2708A600A403031997
    :10004000A5030319A00B11282208672883161C1486
    :100050001A0883169B0A6728A301A200FF30A20793
    :10006000031CA307031C67280330A100E6303A20D5
    :100070002E28A101FC3EA000A109031C4528FF3049
    :100080000000A00703184028A0076400A10F3F2824
    :1000900008000310A00DA10DFF3E031849282008F9
    :1000A00067281030A800A101A001A70CA60C031C12
    :1000B0005F282208A00723080318230FA107A10C1B
    :1000C000A00CA50CA40CA80B5528240867288313A2
    :1000D000031383126400080083168F308600831296
    :1000E00007309F000130A300F4302D20DE200130C6
    :1000F000A300F4302D20DE20FF30C200BE01C40179
    :100100002C21CE21C701A12164004208013C031D1E
    :100110008A28B721CE21832800304607BA0017303D
    :100120000318013EBB00DA2008004408A600A7011E
    :10013000A2010130A3005120B8002508B9003E08F3
    :100140003807BA0039080318013EBB00DA2008005E
    :100150001430392008008616A8200613A82086121D
    :10016000A82008008616A8200617A8200800061652
    :10017000A8208612A8208616A82008000612A8200B
    :100180008612A8208616A8200616A820080001308E
    :10019000BD00640011303D020318D9286400BB1F64
    :1001A000D328B720D428BE200310BA0DBB0DBD0F35
    :1001B000C9280800AB20C720B22008008616061602
    :1001C0000617BA013030BB00DA2032302C20BA01D9
    :1001D0003030BB00DA2032302C20DB30BA00BB01DB
    :1001E000DA2032302C20BA011030BB00DA20323055
    :1001F0002C20CC30BA00BB01DA2032302C20BA01DE
    :100200001030BB00DA2032302C20BA011230BB0093
    :10021000DA2032302C20D430BA001A30BB00DA2079
    :10022000CF30BA001730BB00DA202E30BA001030C1
    :10023000BB00DA20C030BA00BB01DA20C301640081
    :100240000B30430203182B29C430BA001030BB0016
    :10025000DA20C30F1F290800C801C701BA01BB017A
    :10026000DA200B30BA001730BB00DA20C70A64006E
    :100270001C304702031C3E29C701C80A64000B302A
    :10028000480203184429312908007F30C600FF3096
    :10029000A200A20A2208433C031CA02955213C02CB
    :1002A000031D49292208C600A02901308A0022081E
    :1002B0005C3E03188A0A82003034313432343334DD
    :1002C0003434353436343734383439342D342034FA
    :1002D000413442344334443445344634473448345A
    :1002E00049344A344B344C344D344E344F3450340A
    :1002F00051345234533454345534563457345834BA
    :1003000059345A343A342E342F3427346134623419
    :1003100063346434653466346734683469346A3409
    :100320006B346C346D346E346F34703471347234B9
    :1003300073347434753476347734783479347A3469
    :1003400008000230C4001730BE009520C0016400D0
    :10035000053040020318B629400883169B0083121B
    :100360002620BC0045218C20C00FA729080005309D
    :10037000C4000430BE0095200630C0006400183070
    :1003800040020318CD29400883169B0083122620C3
    :10039000BC0045218C20C00FBE290800C5010430D7
    :1003A000A200A3010630840080300120C500640053
    :1003B000013045020318EF2964004208013C031D87
    :1003C000E2290800CE30BA00BB01DA20D530BA00ED
    :1003D0001A30BB00DA200130C2002C210800640072
    :1003E0004208003C031DF5290800CE30BA00BB01CD
    :1003F000DA20D430BA001930BB00DA20C2012C2137
    :020400000800F2
    :02400E00663F0B
    :104200004E005400530043002000FF004E004F00BA
    :104210002000530059004E00430048005300200086
    :104220005200450043004500490056004500440047
    :02423000FF008D
    :00000001FF
