Choice of FET
Results 1 to 7 of 7
Thread: Choice of FET
    Oct 2009
    Default Choice of FET
    Guys and Gals, I'm revamping an old project and need some suggestions on a suitable MOSFET
    I'm only switching 12v up to 2A directly from a PCA9685PW chip, so looking for a 5v logic level trigger. Whilst there are lots to chose from, and the prototype originally had overkill 45A items in a TO220 package I really need to reduce the overall size of the board. Now having 16 FETS on the board somewhat dictates the overall size, so I'm looking for suggestions for a small footprint SMD that can switch 2A @ 12v without needing heatsinks stick to them. If I have to go to a TO92 package then that's fine, but a TO263 SMD package will be a tad too large.
    I've been searching all morning and seem to be going round in circles.. so any suggestions would be welcome
    Default Re: Choice of FET
    what about something like this, I used one to run my rollerdoor (12v windscreen wiper motor)
    SP8K24FRATB 1 tiny soic8 contains two devices only costs a dollar
    Oct 2009
    Hi Richard, thanks for the suggestion.
    In your application, I'm guessing that the current is switched long enough for it to get hot. If I was drawing 2 amps through the device (ie 2 amps per FET) at 12v for upwards of 6 hours would the device get hot? I've looked at the datasheet and it says something about 2w total power dissipation, but I confess my ignorance in translating that into real world instances.
    Cheers
    Oct 2009
    Richard, having problems locating them in the UK - Only Farnell stock them, and as I have an account with RS would prefer to get something from them. This is the closest I can find on RS
    http://uk.rs-online.com/web/p/mosfet...stors/8648710/
    Would this suit my needs ?
    Looking at the Farichild FDS 8949 it has a specified Rds-on of 36mOhm (max) at a Vgs of 4.5V and 4.5A drain current.
    36mOhm at 2A drain current equals a power dissipation of 72mW per switch or a ~150mW for both in the package.
    The thermal resistance, when using minimal pads, are specified as 135°C/W so the package temperature will increase by ~20°C, it will feel warm but not hot.
    Looks like it should work just fine as long as you keep the Vgs "up there".
    Oct 2009
    Many thanks guys.. I'll sort out an order and do some real world tetsing
  1. OT - MOSFET choice
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2016, 22:28
  2. Fet for turning on high voltage.
    By jmgelba in forum Schematics
    Last Post: - 22nd February 2013, 08:26
  3. What is right choice?
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 19:14
  4. Isolated FET
    By DynamoBen in forum Off Topic
    Last Post: - 28th November 2007, 21:09
  5. Correct capacitor choice - OT
    Last Post: - 21st May 2006, 09:49
