How does the code get transferred?
Results 1 to 4 of 4
    Default Re: How does the code get transferred?
    wData is assigned a value and then you GOSUB a routine called SEND.
    SEND, in turn, GOUSBs a routine called OutByte where a loop itterates thru the individual bits in wData and GOUSBs either SendOne or SendZero which puts the state of the bit on the pin aliased as Sda, which in your code is PortC.5, not PortC.3.
    /Henrik
    Mar 2011
    Los Angeles, California
    You are right about it being PortC.5, my oops, just not seeing where it is PortC.5 and not some other Port.
    Cut'n'paste from your program, relevant parts marked with red.
    Pin aliases:
    Clk VAR PORTC.4
     Sda VAR PORTC.5
     Csn VAR PORTC.3
    Variable assignment and call to Send routine:
    WData = $1877: GOSUB Send
    Send routine, calls OutByte:
    Send:
     GOSUB StartCommunication
     GOSUB OutByte
     GOSUB StopCommunication
    Outbyte iterates thru wData and calls either SendOne or SendZero depending on if the bit is a one or a zero:
    OutByte: 'send a 16 bit word
     FOR Bit_Counter = 1 TO 16
     IF wData.15 = 1 THEN 'MSB first
     GOSUB SendOne
     GOSUB SendZero
     WData = wData << 1
     NEXT Bit_Counter
    Sendone:
    SendOne: 'Send a bit 0
     HIGH Sda: GOSUB WasteTime
     LOW Clk: GOSUB WasteTime
     HIGH Clk: GOSUB WasteTime
    Sendzero:
     SendZero: 'sending a bit 1
     LOW Sda: GOSUB WasteTime
  1. Replies: 27
    Last Post: - 9th April 2015, 05:51
  2. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 03:15
  3. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  4. Device programming - how data is formatted and transferred
    Last Post: - 12th February 2008, 11:21
  5. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
