Getting the correct mA from Pic's Pin
Results 1 to 6 of 6
    Sep 2003
    Vermont
    You could use three pins which you power up together, or that 2N2222 needs to be part of the ground return leg of your module. In other words, connect the Emitter to ground, Base to the PIC pin through a 4.7 K resistor, and the Collector to the ground side of your module. If I were to do it this way, I would put a bypass capacitor of .01 uF across the Emitter and Collector leads. To control the positive rail, the 2222 would be attached to the Base of a 3906 through a 2.2K resistor. The 3906 Base is also connected to it's Emitter through a 10 K resistor. The Emitter of the 3906 goes to the positive rail, and the positive side of the module connects to the 3906 collector. A high on the pin would turn the module on.
    Ron
    Dec 2003
    Wichita KS
    just Bias your base of your 2n2222 and connect the emitter to the ground, and the collector to your gadget...
    You will draw your 60 mils... if you don't, then maybe your gadget does not need 60mils!...
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    @sda's Avatar
    @sda Guest
    Why power the module via its ground pin?
    Not very safe practice.
    AFAIK, the 2N2222 is a NPN device, so you'll have to conect its collector to the power rail, base via a 100r resistor to your output port, and the emitor to your module.
    The output will be (power rail) 5v - 0.7 (transistor drop) = 4.3v
    Cheers sda
    Thank you very much for all the replies!!!
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Epic Plus Programmer and 8 pin PICs
    By Peaps in forum Off Topic
    Last Post: - 25th February 2008, 10:25
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
