LCD -- melabs sample program
Results 1 to 16 of 16
    Default Re: LCD -- melabs sample program
    do you have the unused data pins 4 to 7 tied to gnd along with the r/w pin ?
    I think that should be
    do you have the unused lcd data pins 0 to 3 tied to gnd along with the r/w pin ?
    can't remember don't use them much . point is the pins should not be left floating
    Oct 2009
    The only difference I can see between your example code and the code I use for LCD in my projects is that my code has
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    After the definition for LCD_Lines
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    I always use PORTB as I have an EasyPIC development board and that's the default wiring for the LCD, so can't comment on using pins on other ports for the enable / reset lines, but in theory, if they are set to digital it should be OK
    Yes Scampy, I had that in the code as well but commented it out -- tried it both ways. No go. This is so weird. And yes, I have rw tied to ground but not the unused data pins on the LCD -- heading to the workbench to try that.
    always something embarrassing -- in my frustration to try everything, forgot to move data to db0 - db3. it was still on the default of db4 -- db7
    head in sand.
    May 2012
    Merseyside, UK
    Quote Originally Posted by Michael View Post
    head in sand.
    I did exactly the same the other day......Any room in that sand ???
    Andy
  1. Lcd 16x2 circuit and sample program...
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2012, 12:21
  2. melabs U2 programmer won't program 12F675
    Last Post: - 21st November 2011, 02:14
  3. meLabs Program Header aid
    By boroko in forum General
    Last Post: - 13th November 2009, 10:37
  4. CTCSS Tone Decoder Sample Program
    By sozkarabacak in forum General
    Last Post: - 20th October 2009, 07:15
  5. DS1307 sample Program
    By Mark in forum mel PIC BASIC Pro
    Last Post: - 29th September 2004, 03:25
