LCD -- melabs sample program
Results 1 to 16 of 16
    Default Re: LCD -- melabs sample program
    contrast is fine.
    I have a few thousand 16c72.
    just a beginner with LCDOUT. It's using default ports is something you don't think of.
    Ok, I give up. Hours spent on this. Maybe someone could be so kind as to look at the code and see why this doesn't function. Something simple perhaps. I realize the 16C72 is an antiquated part but I have a ton of them. I even used another LCD (yes hd44780's) -- even tried another xtal etc. Mclr is high to Vdd, ADCON1 is making pins digital. Changed the defaults because A4 isn't TTL on the 16C72 so used B7 and C7 for RS and E to avoid conflicts -- even did a TRIS on all the pins. Power supply is fine -- this is crazy.
    DEFINE OSC 4 '16C72
    ADCON1 = 7
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0 'a0 thru a3
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 7
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Pause 1000 ' Wait for LCD to startup
    mainloop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto mainloop ' Do it forever
    and for what it's worth all I get are a group of 16 squares on the 2nd line
    do you have the unused data pins 4 to 7 tied to gnd along with the r/w pin ?
    I think that should be
    do you have the unused lcd data pins 0 to 3 tied to gnd along with the r/w pin ?
    can't remember don't use them much . point is the pins should not be left floating
    Oct 2009
    The only difference I can see between your example code and the code I use for LCD in my projects is that my code has
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    After the definition for LCD_Lines
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    I always use PORTB as I have an EasyPIC development board and that's the default wiring for the LCD, so can't comment on using pins on other ports for the enable / reset lines, but in theory, if they are set to digital it should be OK
    Yes Scampy, I had that in the code as well but commented it out -- tried it both ways. No go. This is so weird. And yes, I have rw tied to ground but not the unused data pins on the LCD -- heading to the workbench to try that.
    always something embarrassing -- in my frustration to try everything, forgot to move data to db0 - db3. it was still on the default of db4 -- db7
    head in sand.
  1. Lcd 16x2 circuit and sample program...
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2012, 11:21
  2. melabs U2 programmer won't program 12F675
    Last Post: - 21st November 2011, 01:14
  3. meLabs Program Header aid
    By boroko in forum General
    Last Post: - 13th November 2009, 09:37
  4. CTCSS Tone Decoder Sample Program
    By sozkarabacak in forum General
    Last Post: - 20th October 2009, 06:15
  5. DS1307 sample Program
    By Mark in forum mel PIC BASIC Pro
    Last Post: - 29th September 2004, 02:25
