LCD -- melabs sample program
Results 1 to 16 of 16
    Default LCD -- melabs sample program
    I've written code far more complex that this but for the very first time I need to engage an LCD and LCDOUT. Believe it or not, I've been in electronics for years but never had the need for an LCD display.
    SO --
    As a very basic introduction, I looked at the sample program here --
    http://melabs.com/samples/PBP-mixed/lcd.htm
    What could be simpler right ?
    BUT --
    It doesn't work and I've triple checked everything. Only to see that in the code, Port A4 and port B3 AREN'T EVEN REFERENCED IN THE FRIGGIN'
    PROGRAM ! They're setup to connect to register select and enable on the LCD BUT why in the hell would they be assigned to a port and then not even used ! ?? And as a sidenote how about making mention of the backlight pins 15 and 16 on the LCD? Think that might be worth mentioning?
    Melabs documentation (to me) has always been piss poor but please, could someone explain why you would connect these pins to A4 and B3 and then do NOTHING with those ports ??? !!! *&$%&()
    Default Re: LCD -- melabs sample program
    I do realize that the ports default low and maybe that's what RS and E need so perhaps that's why they aren't referenced. Whatever is going on with this, i can't get it to work.
    using a 16C72 so I put in adcon1 = 7 and define osc 4 I even tried every combination of RS and E high/low
    Backlight is not part of the LCD controler (HD44780 or compatible) so it's got nothing to do with the LCDOUT command.
    As far as the ports goes I'm not sure I follow. What do you mean by not even used? Have you looked in the generated assembly listing and determined they'r not used or do you mean in the the PBP program?
    They ARE used, behind the scenes, by the LCDOUT command. And what the comments in the example program shows are the default Connection pinout. This can be changed by using a series of DEFINE directives, see the LCDOUT command in the manual.
    There are several reasons for it not working. What chip are you using? Make sure all the pins used for the LCD are configured as digital pins (comparator(s) turned off, digital buffers enabled).
    ever heard of default settings ?
    from the book
    PBP assumes the LCD is connected to specific pins unless told otherwise using DEFINEs. It assumes the LCD will be used with a 4-bit bus with data lines DB4 - DB7 connected to PIC MCU PORTA.0 - PORTA.3, Register Select to PORTA.4 and Enable to PORTB.3.
    have you set port a to be digital ?
    As I said, never picked up an LCD display in my life so yes, knowing the backlight pins beforehand would have been nice. Who's to say the backlight wasn't powered through the Vdd and Vss? If you're new to something, best to spell it all out, right?
    My bad on not considering the code within the command LCDOUT and A4 and B3 being part of it's instruction set.
    It would have been nice to see that in larger print or part of the example. We all are newbies at one point with everything so no need to -- well, you know.
    Thanks kindly for the reply. It must be the fact I'm using a 16c72 but like I say, ADCON1 = 7 sets all pins to digital and it has Ports A & B as most PICs do.
    Everything compiles fine also -- I'll get there. Spent too much time on it yesterday.
    I'll have to look at ADCON1 -- maybe it doesn't influence Port A -- who knows.
    I hope you know the pic16"C"72 is a one time programmable pic vs. pic16"F"72. So you only get one shot to make it work. Also a common beginner's LCD problem is the contrast control.
    contrast is fine.
    I have a few thousand 16c72.
    just a beginner with LCDOUT. It's using default ports is something you don't think of.
    Ok, I give up. Hours spent on this. Maybe someone could be so kind as to look at the code and see why this doesn't function. Something simple perhaps. I realize the 16C72 is an antiquated part but I have a ton of them. I even used another LCD (yes hd44780's) -- even tried another xtal etc. Mclr is high to Vdd, ADCON1 is making pins digital. Changed the defaults because A4 isn't TTL on the 16C72 so used B7 and C7 for RS and E to avoid conflicts -- even did a TRIS on all the pins. Power supply is fine -- this is crazy.
    DEFINE OSC 4 '16C72
    ADCON1 = 7
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0 'a0 thru a3
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 7
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Pause 1000 ' Wait for LCD to startup
    mainloop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto mainloop ' Do it forever
    and for what it's worth all I get are a group of 16 squares on the 2nd line
    do you have the unused data pins 4 to 7 tied to gnd along with the r/w pin ?
    I think that should be
    do you have the unused lcd data pins 0 to 3 tied to gnd along with the r/w pin ?
    can't remember don't use them much . point is the pins should not be left floating
    Oct 2009
    The only difference I can see between your example code and the code I use for LCD in my projects is that my code has
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    After the definition for LCD_Lines
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    I always use PORTB as I have an EasyPIC development board and that's the default wiring for the LCD, so can't comment on using pins on other ports for the enable / reset lines, but in theory, if they are set to digital it should be OK
    Yes Scampy, I had that in the code as well but commented it out -- tried it both ways. No go. This is so weird. And yes, I have rw tied to ground but not the unused data pins on the LCD -- heading to the workbench to try that.
    always something embarrassing -- in my frustration to try everything, forgot to move data to db0 - db3. it was still on the default of db4 -- db7
    head in sand.
    May 2012
    Merseyside, UK
    Quote Originally Posted by Michael View Post
    head in sand.
    I did exactly the same the other day......Any room in that sand ???
    Andy
  1. Lcd 16x2 circuit and sample program...
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2012, 12:21
  2. melabs U2 programmer won't program 12F675
    Last Post: - 21st November 2011, 02:14
  3. meLabs Program Header aid
    By boroko in forum General
    Last Post: - 13th November 2009, 10:37
  4. CTCSS Tone Decoder Sample Program
    By sozkarabacak in forum General
    Last Post: - 20th October 2009, 07:15
  5. DS1307 sample Program
    By Mark in forum mel PIC BASIC Pro
    Last Post: - 29th September 2004, 03:25
