Programming PIC18f45k20
Results 1 to 2 of 2
    Default Re: Programming PIC18f45k20
    There is no need for the LVP use (I think it is not very reliable).
    You have to use at least the +Vdd, Gnd, Reset, Clk and Data lines of the PicKit3 and connect them to your MCU.
    Best is that this lines are not loaded during the programming. Otherwise, maybe you have to use on board power supply, use isolation to Reset or/and to Clk and Data lines.
    If you power your MCU from the tool, you have to check the power option from the IDE (Power/Power Target Circuit from Tool).
    The attached image shows detailes about the best possible electrical connections for error free programming.
  1. Newbie help. PIC18F45k20 pickit debug express
    By redmobiusv in forum mel PIC BASIC Pro
    Last Post: - 11th August 2011, 18:56
  2. Programming PIC10F222
    By brid0030 in forum General
    Last Post: - 19th August 2009, 23:43
  3. Programming Issues
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 7th July 2009, 20:25
  4. need help programming
    By chris000 in forum General
    Last Post: - 20th May 2009, 06:18
  5. Programming 12f629
    By stay_aliveuk in forum mel PIC BASIC Pro
    Last Post: - 8th October 2006, 19:44
