OK you're using C language but here we use Melabs PICBasic but anyways, let's try to help you on that.
your problem is with this line
Sure if the RX pin is set as an output, it won't work. Just change it and i suspect it will work. but i didn't look the whole thing so i could have miss something.Code:TRISC=0;
Good luck!
