problem with USART
Results 1 to 5 of 5
    Oct 2006
    Unhappy PIC to PIC comm
    hi
    i saw ur coding.i m also doing the same thing.i program is to transmit a string from one pic and receiving the same string in the another pic(USART comm) and displaying the received string in the lcd. my transmit program is working well(got the string in hyper terminal).i have the problem in receiving the string,it s not working.i m using 16f877a and micro c complier.seperately my lcd prgm is also working well
    my code is
    void receive()
    int i=0;
    char s[10];
    STATUS.f5=0;
    STATUS.f6=0;
    for(i=0;i<5;i++)
    while(PIR1.f5==0)
    s[i]=RCREG;
    PIR1.f5=0;
    init_lcd();
    display();
    void main()
    STATUS.f6=0;
    STATUS.f5=1;
    TRISC=0;
    PORTC=0;
    STATUS.f5=0;
    RCSTA=0x90;
    SPBRG=0x20;
    receive();
    while(1)
    if u find any wrong in my code plz help me to correct it
    -Sakthi
    OK you're using C language but here we use Melabs PICBasic but anyways, let's try to help you on that.
    your problem is with this line
    TRISC=0;
    Sure if the RX pin is set as an output, it won't work. Just change it and i suspect it will work. but i didn't look the whole thing so i could have miss something.
    Good luck!
  1. Usart problem with 18F4550
    By maus in forum Serial
    Last Post: - 3rd November 2009, 04:54
  2. byte Tx w/ USART 16f876a problem
    By GargamelDigi in forum mel PIC BASIC
    Last Post: - 15th July 2008, 06:50
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. USART and interrupt latency - not a problem
    By barkerben in forum mel PIC BASIC Pro
    Last Post: - 18th January 2005, 23:57
  5. 16F628 Hardware USART problem
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 26th May 2004, 08:10
