Parsing strings received serially.
Results 1 to 3 of 3
    Default Parsing strings received serially.
    Hi guys,
    I Havent used PBP for quite a while, and I'm afraid my memory is getting rusty.
    I need some help with string parsing.
    I get a stream of data over the serial port in the format !Vxx=yy$
    Where, !V are common start bytes, xx is a 2 digit integer in decimal, followed by "=", and followed by another decimal yyy which could be either single digit, double digit OR 3 digit. And lastly, "$".
    I'll need to fork off to different subd, depending on the value of xx.
    What would be the best way to do this?
    Thanks in advance, guys!
    Default Re: Parsing strings received serially.
    searching the forum still works
    second item seems to cover it
    http://www.picbasic.co.uk/forum/showthread.php?t=17632
    http://www.picbasic.co.uk/forum/showthread.php?t=20953
    Indeed it does; somehow did not stumble across the 2nd thread; Heckler's response looks pretty much what I needed.
    Thanks for the pointer.
    Best Regards,
    Anand Dhuru
  1. Adding values one at a time and sending them serially
    Last Post: - 21st August 2013, 15:56
  2. Question about sending data serially
    By FromTheCockpit in forum mel PIC BASIC Pro
    Last Post: - 1st August 2011, 02:21
  3. Parsing Strings...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 15th February 2009, 05:13
  4. pic18f4550 & pic16f84a serially ?
    By amenoera in forum Serial
    Last Post: - 1st March 2008, 11:51
  5. it's possible to drive four max7221 serially connected?
    By lutherblissett in forum General
    Last Post: - 23rd November 2005, 19:38
