Testing Bits in variables..
Results 1 to 3 of 3
    Default Testing Bits in variables..
    Am I missing something here? I have a declared word variable and byte variable.
    Why can't I test bits in the word variable using the byte variable as the pointer?
    Count1 being 0-9 in this example. I want to test the bits in turn in positions 0-9 using a loop.
    if databyte.Count1 = 1 then
    above causes a compile error "Bad variable modifier"
    Sep 2009
    Default Re: Testing Bits in variables..
    Try:
    if databyte.0[Count1] = 1 then
    Yep, see section 7.6.5 in the PBP3 manual and/or see the [url=http://www.picbasic.co.uk/forum/showthread.php?t=544&highlight=bits+bytes+wordsBit s, Bytes, Words & Arrays[/url] thread starting with Melanies excellent primer on the subject.
  1. Replies: 2
    Last Post: - 23rd April 2013, 16:34
  2. Testing
    By aratti in forum Test Area
    Last Post: - 26th April 2010, 19:15
  3. Don't look! Testing
    By .W4GNS in forum Test Area
    Last Post: - 6th March 2010, 19:58
  4. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 18:42
  5. testing bits
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 23:27
