12F629 maximun Baudrate
Results 1 to 13 of 13
    Zamora, Spain
    Default 12F629 maximun Baudrate
    Hi people, using a 12F629 and programming
    INCLUDE "modedefs.bas"
    DEFINE CHAR_PACING 1 'THIS DOES NOTHING HERE...
    'SET INPUTS AS DIGITAL
    CMCON = %00111111
    lazo:
    serout2 0,32,["1234567890"] '(1)
    pause 20
    goto lazo
    I can see the serial output on my oscilloscope's screen, going at about 19200 baud and repeating with pauses in between. Reading the manual I understand that to set the baud rate to, we can say, 50000 sps, I must program
    1000000/50000 - 20 = 0, instead of 32 in the line (1). If I program a value under 12, I get the pin going from 0 to 5volts (Vcc) randomly and of course no serial signal. The piece is running at 4Mhz from its internal RC oscilator. I read that 12bits PIC does not support serout2 because of its limitations, but it works (PBP v2.46) untill 19200 baud. What I am doing wrong?
    Sep 2003
    Vermont
    There is a lot of info on serial comms on this site. Do a search. Next, if you are going to run over 1200 baud, you NEED a crystal or resonator. RC is just too squirrley. That being said, you can run DEBUG instead of serin, up to 115200 baud....But only with a crystal. Cheers...
    Ron
    Zamora, Spain
    Default I folow your instructions
    I put a 12Mhz cristal to make run a 16F84A. Again, if I try to go faster than around 50K baud (I have got near 90Kbaud programming 57600 and making the PIC believe that its cristal was 3.5Mhz) I got the same rubish out the selected pin for serial output. It happens the same with 12F508, 12F629 and now 16F84A. Also, DEBUG seems to reach a higher baudrate than SEROUT2 on the same µ.
    All these nonsenses are puzzling me. I routinely programm in assembler for 16F876-20 and send data through a twisted pair cable at about 1.125 Mbit/sec.
    Has somebody push the commands SEROUT2 or DEBUG to the limits?
    Thanks.
    Maxi.
    Sep 2003
    Vermont
    Quote Originally Posted by MaxG
    Thanks.
    Maxi.
    I'm sorry, I just don't understand what you're trying to do here. Debug will run to 115K baud. If you want faster, go hardware, or shiftin/ shiftout with a faster clock.
    Zamora, Spain
    Unhappy
    Dear Ron,
    I am sorry for my poor way of self-explaining. I am only trying to transmit some data (16 bytes bursts) at 115Kbaud using a 16F84A, PBP and the command DEBUG or SEROUT. I started doing some testings on 12F629, 12F508... with their internal 4Mhz RC oscillators and I could not go faster than about 30Kbaud. I follow your advise and put a Crystal, 12Mhz, on a 16F84A to make my testings.
    It happens the same; PBP and PIC 16F84A can not go faster than about 80Kbaud, sometimes even slower. DEBUG can not be used with 16F84a and a 12Mhz EXTERNAL HS OSCILLATOR for reaching 115Kbaud. I suppose (I know) that in pieces with specific Hardware for Serial in/out, rates faster than 115Kbaud can be programmed but I would like to know why I can not reach 115Kb with the configuration noted above and where can be found a document with the limits for the commands DEBUG, SEROUT, SEROUT2. Again, I apologize for my short knowledge, and hope that you will be kind enough for taking a glance on my problem.
    Sincerely,
    Maxi.
    Feb 2004
    Germany
    The higher the baudrate the faster and more accurate the clock has to be.
    I doubt you can achieve reliable 115k with only 12MHz Clock speed.
    Try a faster (and calibrated) clock.
    If you have a DSO, scope the output and push it step by step to the limits.
    AND: I wouldn't put anything into production that is ways off specs.
    regards
    Ralph
    Sep 2003
    Vermont
    I've had no issues with a 4 MHz xtal and Debug pushing 115200 baud. Am I doing something wrong(right)?
    Ron
  1. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 23:33
  2. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 05:06
  3. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  4. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
  5. 12F629 I2C problems
    By AIW128ProGuy in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 00:41
