some problem with a pic adc
Results 1 to 3 of 3
    Default some problem with a pic adc
    i try to work with the adc (12bit) of the pic16f1786. My settings are as follows:
    ANSELA = %00010111
    ADCON0 = %01111101 ' Using 12 Bit, Fixed Voltage reference
    ADCON1 = %11110011 ' 2's Compliment, FRC, VREF- to VSS(ADNREF), VREF to FVR
    ADCON2 = %00001111 ' ADC Negative to VSS
    FVRCON = %11001111 ' Enable FVR, and 4.096v Reference
    WPUA = %00000000
    But when I try to acquire from a source it gives me a somewhat incorrect value, if I dont understand it. The measured source with the digital voltmeter gives 1.40 volts while the pic gives me the value 1435. But with a fvr of 4.096 volts and 12 bits (4096 levels) does not have a 1: 1 ratio? That is 1435 means 1,435 volts?
    Default Re: some problem with a pic adc
    If I read the datasheet properly the accuracy specification on the FVR is +/- 3% so you're still within that window.
    Vdd must be above 4.75V and there's a comment saying the specification is valid for the industrial temperature range part only. What's your Vdd and exact part number?
    Also, are you doing any filtering/averaging in your code? You might benefit from that if you have noise coupled into your signal which your DMM filters out.
    thank you henrik, the averaging seems to be good but today i will try to check the "zeroing", maybe the problem is there. the Vdd comes from a common 7805 and it's something near 4,97 volts....
  1. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 21:22
  2. ADC problem :(
    By Kaldurenik in forum mel PIC BASIC Pro
    Last Post: - 4th December 2007, 15:54
  3. ADC problem
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 00:21
  4. Problem with ADC
    Last Post: - 25th November 2006, 08:37
  5. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:27
