Code trouble
Results 1 to 5 of 5
Thread: Code trouble
    Aug 2005
    Los angeles
    Angry
    still doesn't work... i don't see what's the problem with mine. the program never gets to wakeup.
    Aug 2005
    Los angeles
    Question
    I got it to work...initially i though that the 1ms pause and i am doing a 10000 loop i would get about 10 seconds delay...but it turned out that this is not correct i would get about 56 seconds delay for 2700 loop not sure why it took so long to execute all these functions
    All the other commands require processing time which can certainly add up over these kinds of execution times. I'm sure if you calculate how long each command take to process you will find your time is pretty close if not bang on. Especially is say one command take 1ms to process then you would have added 2.7s to the time right off the bat.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Microchip MCP41xxx Digital Potentiometer Code Trouble
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 19:21
