Code trouble
Results 1 to 5 of 5
Thread: Code trouble
    Aug 2005
    Los angeles
    Default Code trouble
    Can anyone spot my mistake in this simple program. The program run but it will never go into the wakeup mode. thank you much see below:
    ' this is for pic12f675
    ANSEL=0 ' change pin into digital Input
    CMCON=7
    pulsewidth var word
    counter var word
    looptime con 10000
    pulsin 4,1,pulsewidth ' read the pulse width at pin 4
    for counter=0 to looptime 'loop
    if pulsewidth >150 then gosub switch ' read pulse width again
    if pulsewidth=0 then gosub blink
    pause 1
    if counter=looptime-1 then gosub wakeup
    next counter
    switch:
    low 2 'pin 2 becomes ground =20 ohms resistance w ground
    input 2 ' pin 2 becomes open collector means high impedance
    counter=0 ' reset the counter
    ' : wake up will do the same thing as the switch function above but only after
    ' the loop times out
    wakeup:
    counter=0
    blink: ' blink the led
    high 0
    pause 80
    low 0
    pause 80
    counter=0
    I would have to say your problem is using an "IF" statement inside the "FOR...NEXT" loop. Also you do realize the PAUSE 1 = 1mS and not 1s. I also noticed there is not main program loop, do you in fact what the program to stop once it has read the pulse width?
    start:
    counter = 0
    loop:
    counter = counter + 1
      gosub switch
      gosub blink
    pause 1
    if counter = (looptime - 1 ) then
      gosub wakeup
    goto start
    switch:
    blah, blah, blah...
    blink:
    blah, blah, blah...
    wakeup:
    blah, blah, blah...
    Aug 2005
    Los angeles
    Angry
    still doesn't work... i don't see what's the problem with mine. the program never gets to wakeup.
    Aug 2005
    Los angeles
    Question
    I got it to work...initially i though that the 1ms pause and i am doing a 10000 loop i would get about 10 seconds delay...but it turned out that this is not correct i would get about 56 seconds delay for 2700 loop not sure why it took so long to execute all these functions
    All the other commands require processing time which can certainly add up over these kinds of execution times. I'm sure if you calculate how long each command take to process you will find your time is pretty close if not bang on. Especially is say one command take 1ms to process then you would have added 2.7s to the time right off the bat.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  3. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  4. Making Program Code Space your playground...
  5. Microchip MCP41xxx Digital Potentiometer Code Trouble
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 19:21
