Serial over the IR
Results 1 to 13 of 13
    Aug 2003
    Default Re: srial over the IR
    You shouldn’t need another pic, just turn on HPWM, and leave it on.
    then use that as one input to an AND gate, and your HSEROUT pin as the other,
    then the AND gate output should be the modulated serial.
    The IR receiver modules don’t go well with a constant carrier, at least in my experience,
    and also your output from the IR receiver module might be inverted (relative to what you expect).
    You might need a 7404 or similar at either the send or the receive end.
    Jan 2006
    Istanbul
    Lightbulb Re: srial over the IR
    If the received data is like a garbage, then reverse IR LED legs.
    Jun 2008
    Varese , Italy
    good idea Sayzer,
    thanks,
    Ambrogio
    USA - Arizona
    Take a look at the following, these show you some simple information about RX/TX IR communication and some basic code:
    Basic IR Communications (http://www.electro-tech-online.com/a...nications.361/)
    Lazer Tag– concept (http://www.electro-tech-online.com/b...3-concept.216/)
    Jun 2008
    Varese , Italy
    thanks,
    I did register but not possible to get in due to error: could you pls specify the links again ?
    Ambro
    USA - Arizona
    Not sure if you were referring to the following links; but just in case they are posted below in full:
