Andy, this is the routine I use for a 4 line LCD on my EasyPIC5 board
Code:DEFINE LCD_DREG PORTB ' LCD Data port DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4) DEFINE LCD_EREG PORTB ' LCD Enable port DEFINE LCD_EBIT 5 ' Enable bit (on EasyPIC 5 LCD) DEFINE LCD_RSREG PORTB ' LCD Register Select port DEFINE LCD_RSBIT 4 ' Register Select bit (on EasyPIC 5 LCD) DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits) DEFINE LCD_LINES 4 ' number of lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us
If you have a 2 x 16 or 2 x 20 LCD then change the DEFINE LCD_LINES 4 to DEFINE LCD_LINES 2
