MCSP BootLoader and Configuration Fuses
Results 1 to 2 of 2
    Default MCSP BootLoader and Configuration Fuses
    Is there a way to enable the x4 PLL for using the BootLoader? I tried programming the PIC in the EPIC programmer and it works fine as long as I don't change any of the configuration properties prior to programming the chip. If I change anything the Loader keeps complaining a reset is required. I want to run at 16MHz (4MHz x 4) but I don't want to have to pull the chip out all the time to reprogram it. The loader option is really handy.
    Thumbs up David @ MCSP Saves The Day
    I just received an email back from David Barker, the person behind MCSP, and he sent me a PLL16 and PLL40 HEX file for the loader. Everything works great now. I received a reply to my email that I sent in about 15-30 minutes. Now if only all customer support and service was this way
  1. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 02:10
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Coding Style - PIC 18F4620 config fuses
    Last Post: - 8th January 2008, 21:05
  4. Disabling bootloader under program control
    Last Post: - 14th March 2007, 16:35
  5. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
