Digital output (RA5) on 16f884
Results 1 to 8 of 8
    May 2012
    Merseyside, UK
    Default Digital output (RA5) on 16f884
    Help......
    Hi Thank you for reading..... I am attempting to output 16 Leds on ports A and C using a 16F884
    All is working ok but for RA5 (Pin7)..... I suspect I have not turned of an analogue function but what one..
    Any help welcome..... all code is working fine but for this pin.... It just stays high all time !
    See my headers below.
    Andy
    '__config _CONFIG1,
    '_INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF &_CDP_OFF
     '__config _CONFIG2, _WRT_OFF & _BOR40V
    'Port A Leds
    'Port B Buttons with Internal Pullups
    'Port C Leds
    'Port D Display
    ' LCD should be connected as follows:
    '       LCD     PIC
    '       DB4     PortD.0
    '       DB5     PortD.1
    '       DB6     PortD.2
    '       DB7     PortD.3
    '       RS      PortD.4
    '       E       PortD.5
    '       RW      Ground
    '       Vdd     5 volts
    '       Vss     Ground
    '       Vo      50K potentiometer (or ground)
    '       DB0-3   No connect
        OSCCON = $70    'Sets internal Osc at 8Megs
        ANSEL=0         'Turn off Analogs
        ANSELH=0
        ADCON0=0
        ADCON1=0
        CM1CON0=0
        CM2CON0=0
        CM2CON1=0
        CCP1CON=0
        CCP2CON=0
        OPTION_REG.7=0  'Port B Pullups active
        TRISA=0         'PORT A Outputs
        TRISB=15        'PORT B Inputs
        TRISC=0         'PORT C Outputs
        DEFINE LCD_DREG PORTD
        DEFINE LCD_DBIT 0
        DEFINE LCD_RSREG PORTD
        DEFINE LCD_RSBIT 4
        DEFINE LCD_EREG PORTD
        DEFINE LCD_EBIT 5
        DEFINE LCD_BITS 4
        DEFINE LCDLINES 2
        LED0 VAR PORTA.0
        LED1 VAR PORTA.1
        LED2 VAR PORTA.2
        LED3 VAR PORTA.3
        LED4 VAR PORTA.4
        LED5 VAR PORTA.5
        LED6 VAR PORTA.6
        LED7 VAR PORTA.7
        BUT0 VAR PORTB.0
        BUT1 VAR PORTB.1
        BUT2 VAR PORTB.2
        BUT3 VAR PORTB.3
        BUT4 VAR PORTB.4
        BUT5 VAR PORTB.5
        BUT6 VAR PORTB.6
        BUT7 VAR PORTB.7
        LED8 VAR PORTC.0
        LED9 VAR PORTC.1
        LED10 VAR PORTC.2
        LED11 VAR PORTC.3
        LED12 VAR PORTC.4
        LED13 VAR PORTC.5
        LED14 VAR PORTC.6
        LED15 VAR PORTC.7
    May 2012
    Merseyside, UK
    Default Re: Digital output (RA5) on 16f884
    Hi All
    Looked at this a little bit further..... I now believe it is RB5/AN13/T1G Causing me the issue.
    Maybe the T1G Timer ??
    How do I disable this and make the port just a DI
    Many thanks
    Andy
    Aug 2011
    TRISB = 15
    You're only setting RB0-RB3 as inputs
    Andy, Make sure CM2CON1 is set to all zero's.
    CM2CON1 = %00000000
    This register defaults to T1GSS to T1G enabled at power on. I don't however believe that is the problem.
    EN82fn
    May 2012
    Merseyside, UK
    TRISB = 15
    Thanks both for help..... Missing the obvious, for some reason I copied and pasted previous code, but left TRISB as 15.
    Changed to 255 and all works now......
    Thank you again
    Jan 2006
    Slovenia EU
    You have porta set to output try with resistor 4K7 between RA5 and VCC.
    Just a tip for visual people like me:
    - use individual bits for fuses, it's much easier to determine which bit is ON or OFF.
    For example:
    TRISB=%00001111
    versus
    TRISB=$0F
    versus
    TRISB=15
    May 2012
    Merseyside, UK
    For example:
    TRISB=%00001111
    versus
    TRISB=$0F
    versus
    TRISB=15
    Very good advice.... My problem is disciplining myself to carry it out.
    Maybe I need slow down a bit :-)
    BR
    Andy
  1. Fuses issue on 16f884.... Locked out ??
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 18th May 2017, 14:50
  2. Port Digital Output Not Changing Properly
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 26th March 2017, 07:06
  3. PIC16F685 RA4/RA5 pins
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:45
  4. open drain output as digital output?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 03:11
  5. Rx433 linear and digital output
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 29th October 2006, 21:26
