using gp3 12f629
Results 1 to 5 of 5
    Tallinn, Estonia
    Hi!
    Yes, this kind of arrangement is possible. I have used GP3 as an input for several circuits, the R-dimmer for instance. But note: better connect a protecting diode from GP3 to +U (power). Without it the device might spuriously reset if your input voltage somehow goes little higher than +U .
    Of course you loose reset input but if you configure the device with power-up timer ON, MCLR OFF, it works fine.
    Aug 2005
    down south
    thanks Felch
    just to make sure something like a 4001 diode and anode to GP3
    and thanks for the MCLR off and power up on. config. changes was going to be my next ? And I am sorry for not being real smart on this stuff trying to learn but what effect will not having the reset cause?
    thanks again
    Tallinn, Estonia
    Hi!
    Reset will cause starting your code from beginning. In most likely position, of course, Murphy's law really is phundamental .
    . You can not simulate it, it's a hardware design error. In MBLAB sim. everything works fine. I made this mistake, then became suspicious about feeding signal to MCLR input. Changed pin and - voila - everything worked splendidly. I asked Microchip about the phenomena, they admitted that if signal amplitude on MCLR rises above recommended values, everything might happen. Anyway, after connecting a diode (1N4148 in my case) no more mysteries took place.
    Btw, it was signal from MIC amplifier cathching whistle sounds.
    Power-up timer makes no harm. Without it i'd use software timed wait loop before doing anything serious. Helps a lot! Especially in case of cheap and noisy power supplies...
    The timer delays all processor activities for some time after powering on. Just like having a cap connected to reset pin but...now you can use reset pin for other purposes. I think it is a useful feature.
    Aug 2005
    down south
    thanks again I will be using a reg. 5v from batterys And I would like to take GP3 low to trigger, my code is simple stuff using Pauses between diffrent output. and somtime sleep, refresh, and interup and a few Vars here and there
    by triggering low ( using a 2222 transitor ) would the would I still need the diode or have to worry about reset
    thank you for you time and help, I a enjoy doing this just hate to bother people with my ?'s
  1. 12f629 config settings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 22:39
  2. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 04:06
  3. GP3 Funtion on PIC10f202
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 19:49
  4. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 23:34
  5. wierd problem with 12f629 Need Help Despretly
    By Nadeem in forum Off Topic
    Last Post: - 15th June 2005, 20:59
