Hi guys,
I have a home made capacitive sensor I intend to use to measure the depth of water with.
Seems to work fine, but here is the issue.
I am *not* interested in the absolute value of the capaity in terms of uF or nF etc.
The test sensor is a foot long; when it is completely out of the water reservoir, I get a value of 10. This would be the capacity created by the cable, connector etc.
When its fully immersed, the value is 60.
Now, I need to output the reading on a scale of 1 to 100, as a percent. So, 10 would correspond to 1 (or 0?), and 60 to 100.
Therefore, is calculating the percent as simple as (Actual_Reading-Reading_Min)*100/(Reading_Max-Reading_Min)?
I plotted the actual readings taken at 0%, 25%, 50%, 75% and 100%, and the expected computed values, and there is a slight discrepency.
X axis is the inches of the probe under water, and y axis is the reading.
Is there a better way of scaling, as against the formula I've used, for a better fit?
