sorting array
Results 1 to 4 of 4
Thread: sorting array
    Jul 2006
    Lazio, Italy
    Default sorting array
    Hi, i would need help to solve a problem. I have 9 variables that contain the penalties found in a car race. I have to put them in ascending order and form a ranking by keeping the variable name or assigning a new one but without losing the reference to the starting variable. I tried it with an array but in this way I get the array values sorted but I lose the link to the variable name. Is there a way to sort the array while keeping the link to the name of the individual variable? Thanks.
    car1/car9 variable
    starting situation
    car1=54 penalty
    car2=81
    car3=25
    car4=14
    car5=6
    car6=29
    car7=77
    car8=32
    car9=44
    after sorting
    1) car5
    2) car4
    3) car3
    4) car6
    5) car8
    6) car9
    7) car1
    8) car7
    9) car2
    Default Re: sorting array
    this works
    'car1=54 penalty
    ' car2=81
    ' car3=25
    ' car4=14
    ' car5=6
    ' car6=29
    ' car7=77
    ' car8=32
    ' car9=44
    num_cars   con 9
    cars var byte[num_cars*2]
    carw var word ext
    tmp var word
    sw_flag var bit
    car_cnt var byte
    car_cnter var byte
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    pause 2000
    Debug "Start",13 ,10
    @carw = _cars
    arraywrite cars,[1,54,2,81,3,25,4,14,5,6,6,29,7,77,8,32,9,44]
    car_cnt =0
    while car_cnt <  num_cars
    debug  13,10,#carw[car_cnt]//256,9,#carw[car_cnt]/256
    car_cnt =car_cnt +1
    wend
    gosub sort
    car_cnt =0
    debug  13,10
    car_cnt =car_cnt +1
    wend
    debug  13,10
    sort:
    sw_flag =0
    car_cnt =0
    while car_cnt <  (num_cars -1  )
         tmp= carw[car_cnt+1]        ;word pointer
         car_cnter= car_cnt*2 +1      ;byte pointer
         if   tmp.highbyte < cars[car_cnter]  then
              carw[car_cnt+1] = carw[car_cnt]
              carw[car_cnt] =tmp
              sw_flag =1
         car_cnt=car_cnt+1
     wend
     if  sw_flag then goto sort
    print out
    1, 54
    2 ,81
    3, 25
    4 ,14
    5 ,6
    6, 29
    7 ,77
    8, 32
    9 ,44
    5 ,6
    4 ,14
    3 ,25
    6, 29
    8, 32
    9 ,44
    1 ,54
    7 ,77
    2, 81
    Jul 2006
    Lazio, Italy
    Richard thank you very much for your time you spent for me. Your solution is complex for my knowledge. However, I will analyze it carefully. You did a lot more than I asked for. I'll let you know the developments of my work. Thanks again
    Setup 2 arrays, car number/name and penalty. Do a bubble sort on penalty and for each swap not swap step do the same to the car number/name array.
    George
  1. Sorting arrays
    By mark_s in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2012, 16:01
  2. Sorting blocks of data in EEPROM
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 8th November 2006, 07:38
  3. Custom array of ports using array?
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 18th June 2006, 01:43
  4. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 15:43
  5. Sorting an Array
    Last Post: - 2nd March 2004, 15:43
