HEX value o/p to PC and arrays
Results 1 to 14 of 14
    Christos_K's Avatar
    Christos_K Guest
    Default HEX value o/p to PC and arrays
    Hi all. I was wondering how can I send to the terminal of my PC using MAX232 the hex value of a variable.
    hserout [dummydata] will give me the the dec value..Any ideas.
    Also a question about Arrays.
    I want to create an array with byte values in it and read and write to it. Will this be correct:
    Array1 var byte[4]
    for i=0 to 3
    array[i]=i
    i=i+1
    next i
    will this give the following result??
    array1[0]=0
    array1[1]=1
    array1[2]=2
    array1[3]=3
    Thanx!
    Have you tried using HEX2 variable?
    hserout [HEX2 dummydata]
    The 2 after HEX is the number of digits. You can also use DECx for decimal and BINx for binary with x being the number of digits to display.
    array1  var  byte[4]
    for i = 0 to 3
    array[i]=i
    next i
    Your code i believe will screw up the for...next loop because you will be changing the value of i.
    Mar 2005
    Iowa, USA
    Lightbulb
    Quote Originally Posted by CocaColaKid
    array1  var  byte[4]
    for i = 0 to 3
    array[i]=i
    next i
    I think this may work better.
    array1  var  byte[3]
    for i = 0 to 3
    array1[i]=i
    next i
    oops, missed those ones
    Mar 2005
    Iowa, USA
    Talking
    Honest mistake.... right on otherwise!
    Quote Originally Posted by Christos_K
    Array1 var byte[4]
    for i=0 to 3
    array[i]=i
    i=i+1
    next i
    array1[0]=0
    array1[1]=1
    array1[2]=2
    array1[3]=3
    Thanx!
    The value of i is automatically incremented by the for next loop, so just remove the i=i+1.
    This will give you the results you're looking for.
    Array1 var byte[4] ' declare a 4-byte array
    for i=0 to 3 ' index array elements 0 to 3 (4 total)
    array[i]=i
    next i
    Array elements start at 0, and end at the declared size-1. I.E. Array VAR BYTE[4] gives you
    4 byte sized elements in the Array that are indexed 0 to 3.
    If you do this;
    Array1 var byte[3]
    for i=0 to 3
    array[i]=i
    next i
    You'll end up placing the 3 in a RAM location outside your 3-byte array.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2005
    Iowa, USA
    Red face You are correct SIR!
    Good catch Bruce.... I see my mistake!
    lol, Bruce, shouldn't it be array1 and not array? Caught you too!
    Ya got me......;o]
    -Bruce
    tech at rentron.com
    Christos_K's Avatar
    Christos_K Guest
    Wow! Thanx for all your answers!! You have been more than helpful! Just one more quick one though...I was not aware of the HEX statement...
    If i want to store to Array1[2] the hex value 0x2A will it be
    Array[2] = HEX 2A
    or
    Array[2] = $2a (as it says on manual page 25) ????
    And if i want to compare the value store in Array[2] with 0x3F will it be
    if array[2] != $3F .....
    or
    if array[2] != hex 3F ???
    Thank you all again so much!!!
