How to verify HS_PLL clock speed
Results 1 to 18 of 18
    "EDIT"
    For OSC2 to output clock/4 with a TTL clock oscillator, you'll need to use EC or ECIO mode.
    HSPLL isn't available for EC or ECIO mode. With a 4MHz TTL clock oscillator, you'll have only 4MHz. HSPLL mode works with the TTL clock if you set config fuses for HSPLL, but you can't use the OSC2 pin in HS mode. Only EC or ECIO modes.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    ah, I'll drop in a crystal then, I have both at my disposable.
    You know, it's not really 100% clear from the datasheet, but looking at Figure 2-2, it does appear an external clock, I.E. a TTL osc can be input to OSC1, and you can select HS, XT or LP modes, so it "appears" you can use a TTL clock in on OSC1, and still make use of the HSPLL as long as you have HS set in config.
    I'll have to experiment with that one.
    -Bruce
    tech at rentron.com
    Just wanted to add that the PLL only starts up properly on Power-Up.
    The first time you program a chip with the PLL turned on, it won't actually start working at x4 untill you turn the power off and on again. A simple reset of MCLR wont do it.
    And it "does" work with a 4MHz TTL clock input with HSPLL set. Just tested it. __CONFIG _CONFIG1H,_OSCS_OFF_1H & _HSPLL_OSC_1H
    You just can't use the OSC2 pin for I/O or clock/4 output without using EC or ECIO mode.
    -Bruce
    tech at rentron.com
    On that note then, using this code it should run at 16MHz internally, correct?
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    @ __CONFIG _CONFIG2L, _BOR_ON_2L & _PWRT_ON_2L & _BORV_45_2L
    @ __CONFIG _CONFIG2H, _WDT_ON_2H
    @ __CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    HIGH portd.1
    PAUSE 500
    LOW portd.1
    PAUSE 500
    GOTO Main
    This reminds me of the old 486DX2 and DX4 microprocessors
    I'm using MPASM version 4.02 which complains if I use the old __config options, so I replaced the old options in the .inc file with:
    CONFIG OSC=HSPLL,OSCS=OFF,LVP=OFF,PWRT=ON,BOR=ON,WDT=OFF, BORV=25,WDTPS=128,CCP2MUX=OFF,STVR=OFF
    DEFINE OSC 16
    LOOP:
    HIGH 0
    PAUSE 500
    LOW 0
    PAUSE 500
    GOTO LOOP
    With the 4MHz TTL input to OSC1, it produces .5 S pulses on RB0. So assuming your programmer isn't altering config fuse settings, and you're getting it programmed with HSPLL, then it should definitely be running at 16MHz internally.
    -Bruce
    tech at rentron.com
  1. Clock Speed
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 24th November 2007, 03:06
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. clock speed
    By Armando Herjim in forum General
    Last Post: - 30th November 2006, 13:25
  5. Faster Clock Speed for Shiftin/out?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 15th December 2005, 03:15
