Mechanique Bootloader
Results 1 to 31 of 31
    Default Re: Mechanique Bootloader
    You're just all over the place aren't you, 3-4 compilers, 2-3 devlopement systems, different IDEs, different bootloaders - it must be confusing. It is for me, trying to follow along what you're trying to acomplish....
    The Firewing board is a PIC18F46K22 loaded with a "special" (ie not MicroCodeLoader) bootloader.
    The AMICUS18 board is a PIC18F25K20 loaded with another "special" (ie not MicroCodeLoader) bootloader.
    The Firewing development board is supported by the free Firewing compiler, just like the AMICUS18 is supported by the free version of the Proton compiler but at the end of the day they are both just a PIC on a PCB and the PBP compiler supports both of those PICs + hundreds of others.
    The "problem" with both the AMICUS18 and Firwing development board is that their respective DRIVER (ie what needs to be installed on the PC) are custom tailored to the specific board (ie, when you plug it in it shows up as an AMICUS18 or a Firewing Communication port (despite it being just Another COM-port)) in the device manager of the PC. This allows the their specific bootloader application on the PC (ie not MicrCodeLoader) to find the board without knowing which COM-port it is but it also means that A) it won't work on Windows 10 (becasue the device driver is not signed and Windows 10 refuses to load it) and B) it won't easily allow you to load ANOTHER, generic, bootloader (like the MicroCodeLoader) into the PIC without first messing about with FTDI chip on the board, changing its settings so the board presents itself as a normal COM-port.
    1) Choose a PIC that can do what you need
    2) Choose a compiler that can generate code for the desired PIC
    2) Choose an IDE that integrates with the compiler (or don't, it's not strictly NEEDED).
    4) Then, optionally, choose a bootloader that works with the PIC you're targeting.
    Don't try to do it all at once.
    Mar 2017
    Henrik
    Did not get email alert about your response.
    "Don't try to do it all at once."
    It's more a case of looking into how 'user friendy' and 'wallet friendly' different Basic's are.
    Using a PICKit3 makes them all wallet friendly.
    Just not like the old days of Basic Stamp where you could click and download.
    That definitely corrupts people for later work with PIC's.
    Good point about Amicus w/Proton and Firewing w/Swordfish.
    Putting a PIC on a breadboard is very wallet friendly.
    Have you noticed nobody has replaced the Olimex 14 pin PIC boards etc. with USB versions?
    Now on to 'How much are Proton and Swordfish like Basic Stamp Basic?'.
    PICBasic is very much like PBasic and then it has plethora of more specific commands.
    Very much like CCS compilers.
    Aug 2011
    If you want something that looks like a BASIC Stamp then PBP is what you want.
    All the others are very different.
    Mar 2017
    Tumbleweed
    Thanks.
    Just getting to how the language is. Want to sort out hardware first.
    I could not download Firewing compiler. The link was bad.
    I can see Microcode bootloader is going to become a side project.
    Best plan is to just 'take the .hex file and run'.
    Load it into MPLAB IPE and program chip on board.
    Aug 2011
    You don't have to use the IPE software to program the chip.
    MPLABX (and the older MPLAB) has command-line drivers for each of the programmers (PK3, ICD3, etc).
    Using these you can add the Pickit3 as a programmer to the MicrocodeStudio IDE and then you can program the chips directly from there.
    That way you don't need a bootloader at all.
    And I've written a post about how to setup the IPE command line tool in MicroCodeStudio, here it is. It then becomes a seamless one click compile and program that works with any and all PIC that compiler supports. It just tends to be a little slower than using a bootloader.
    except the newer ones like pic16f1615,pic16f1619 ,pbp3 supports them pk3 ipe does not.
    I have not tried with mplabx version past 2.35 [the latest version that works with pbp3 afaik ]
  1. Bootloader
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 15th April 2012, 20:46
  2. Where is the bootloader ?
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 19th September 2011, 14:43
  3. PROBLEMS ORDERING PICBASIC PRO mechanique.co.uk
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 27th September 2009, 20:11
  4. bootloader
    By pierre2030 in forum mel PIC BASIC Pro
    Last Post: - 28th January 2007, 22:24
  5. bootloader
    By Mostafa in forum General
    Last Post: - 22nd February 2006, 13:34
