Amicus 18 FTDI driver on W10?
Results 1 to 23 of 23
    Default Re: Amicus 18 FTDI driver on W10?
    Thanks Dave,
    Guess it's time to figure that UMC loader out, never had the need before.
    Dave,
    If you don't mind me asking, are you using the UMCBuild application to create your bootloader .hex files or are you building them manually in MPLAB?
    I've just read thru the documentation and have attempted to create a .hex file using the UMCBuild application but needless to say I'm struggling. The application says it can't find the MPASM executable, something the docs says it should be able to do if I have a working environment (which I do). I suspect the issue is that it's looking for MPASM.exe while it's now called MPASMX.exe.
    I tried adding the path to MPASMX in the [PATH] section of the UMCBuild.ini but I get either Can't find MPASM executable or Can't find MPASM path. I tried making a copy of MPASMX.exe, renaming it to MPASM.exe but still can't make it work.
    Would you mind sharing some of your knowledge regarding the UMC?
    Aug 2011
    Try renaming mpasmx.exe to MPASMWin.exe. That's the name of the old assembler.
    Well of course it is! Thank you for reminding me!
    Making progress but still not all the way. Placing a copy of MPASMX with its name changed to MPASMWIN.exe and adding the following line to the UMCbuild.ini file made THAT error go away
    MPASM=C:\Program Files (x86)\Microchip\MPLABX\v3.55\mpasmx
    It then complained it couldn't find the MPLAB device path so I added the following:
    DB=C:\Program Files (x86)\Microchip\MPLABX\v3.55\mpasmx
    (Because, just as with the assembler, that's where all the device specific assembler .inc files are located - which I assumed was what it's looking for...)
    But now it says No device file found for "18F452"
    Anyone have any ideas?
    Henrick, I have my "Mecanique" directory mounted off my root directory on "C:/" drive. I have never used the "PATH" directives since I have mounted it on my Windows 8 machine about 3 years ago. Even when I had my Windows "XP" machine I had it mounted in the same way. Make sure the device you are trying to program in in the devices.ini file located under "Mecanique/MCSPX/MCLoader/umc/src/18F/". For new devices you will have to make new entries into this .ini file.
    EN82fn
    hi Henrik
    I do it this way , it may not be the best way but it works for me
    created folded
    c:\myBOOTLOADER
    made a subdir for each chip i use
    c:\myBOOTLOADER\16f1825
    c:\myBOOTLOADER\18f25k22
    in each folder the modified config.ini file to suit that chip
    to compile loader
    copy chosen config.ini to c:\myBOOTLOADER
    then using dos shell
    cd to working dir
    CD C:\Program Files\Mecanique\MCSPX\MCLoader\umc\build
    run compiler
    umcbuild.exe "c:\myBOOTLOADER\config.ini"
    output is in c:\myBOOTLOADER\"chosen pic folder"
    note
    C:\Program Files\Mecanique\MCSPX\MCLoader\umc\src has two sub dirs
    16f and 18f , in these are the device.ini files you may need to add your chips to these files if they are not included
    16f1825 ini
    ; optional path information - default output folder is
    ; user documents -> umcbuild...
    [PATH]
    Output=C:\MYBOOTLOADER
    [TEMPLATE]
    ;PIC18=..\src\18F\umc_loader.asm
    PIC16=..\src\16F\umc_loader.asm
    ; device name and OSC...
    [MCU]
    Device=16F1825
    OSC=32000000
    [USART]
    BAUDRATE = 19200 ; initial startup baudrate (default is 19200)
    BRGH16 = 1 ; 16 bit SPBRG support (default is OFF)
    ; device configuration settings...
    [CONFIG] ;----- CONFIG1 Options --------------------------------------------------
     __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
     __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
    ; place startup code in here...
    [USERCODE]
     movlb 1
     BCF TRISC,4
     BSF TRISC,5
     ;movlb 1
     movlw 0xF0 ; 32 MHz
     movwf OSCCON
     btfss OSCSTAT,6
     goto $-1
    1825k22 ini
    [PATH]
    ; source code files...
    [TEMPLATE]
    [USART] BAUDRATE=19200 BRGH=1 BRG16=1
    [MCU]
    Device=18F25K22
    OSC=64000000
    [CONFIG]
    config FOSC = INTIO67
    config PLLCFG = OFF
    config PRICLKEN = ON ; Primary clock Enabled
    config FCMEN = OFF ; Fail-Safe Clock Disabled
    config IESO = OFF ; Oscillator Switchover Disabled
    config PWRTEN = ON ; Powerup Timer Enabled
    config HFOFST = OFF ; HFINTOSC delayed until oscillator stable
    config BOREN = ON ; Brown Out Detector Enabled
    config BORV = 250 ; VBOR set to 2.50 V nominal
    config WDTEN = OFF ; WDT Enabled; SWDTEN bit has no effect
    config WDTPS = 512 ; WDT = 1:512 = 2048 ms
    config CCP2MX = PORTB3 ; CCP2 i/o is multiplexed with RB3 (not RC1)
    config CCP3MX = PORTB5 ; P3A/CCP3 i/o is multiplexed with RB5 (not RC6)
    config T3CMX = PORTB5 ; T3CKI is on RB5 (not RC0)
    config P2BMX = PORTC0 ; ECCP2 P2B is on RC0 (not RB5)
    config PBADEN = OFF ; PORTB<5:0> pins configured as digital i/o (not analog)
    config MCLRE = EXTMCLR
    config STVREN = ON ; Stack Overflow Reset Enabled
    config XINST = OFF ; Extended Instructions Disabled
    config LVP = OFF ; Low-Voltage-Programming Disabled
    config CP0 = OFF ;Code Protect 00800-03FFF
    config CP1 = OFF ;Code Protect 04000-07FFF
    config CP2 = OFF ;Code Protect 08000-0BFFF
    config CP3 = OFF ;Code Protect 0C000-0FFFF
    config CPB = OFF ;Code Protect Boot
    config CPD = OFF ;Data EE Read Protect
    config WRT0 = OFF ;Table Write Protect 00800-03FFF
    config WRT1 = OFF ;Table Write Protect 04000-07FFF
    config WRT2 = OFF ;Table Write Protect 08000-0BFFF
    config WRT3 = OFF ;Table Write Protect 0C000-0FFFF
    config WRTC = OFF ;Config. Write Protect
    config WRTB = OFF ;Table Write Protect Boot
    config WRTD = OFF ;Data EE Write Protect
    config EBTR0 = OFF ;Table Read Protect 00800-03FFF
    config EBTR1 = OFF ;Table Read Protect 04000-07FFF
    config EBTR2 = OFF ;Table Read Protect 08000-0BFFF
    config EBTR3 = OFF ;Table Read Protect 0C000-0FFFF
    config EBTRB = OFF ;Table Read Protect Boot
    [USERCODE]
    movlb 0x0F ; MANDATORY: BSR set to SFR bank
    movlw b'00000000'
    movwf ANSELC ; MANDATORY: analog off on port C
    movlw 0x70
    movwf OSCCON
    bsf   OSCTUNE,6
    BTFSS OSCCON2,7
    BRA $-2
    Thanks guys!
    Are you both using MPLABX/MPASMX or do you also have an older version of MPLAB installed? I thought I'd try to bloat this new computer down with all sort of software but that seems impossible to avoid. Microsoft won't properly support Win7 on new generation CPU(s), the Amicus loader doesn't work on Win10, the UMC loader doesn't work with MPLABX....it just never ends :-(
    I'm trying to build a bootloader .hex for the 18F452 - which is what the default .ini file is configured to do. As far as I can see it's one of the default devices but I may be wrong. I thought I'd get that going first before trying to configure it for other chips.
    Aug 2011
    I've never tried building the bootloader using mplabx, and I only have the UMC stuff from swordfish and proton so take this with a grain of salt...
    Some of the [PATH] options in the umc.ini file specify the MPASM and DB paths. You can fool it to use mpasmx.exe as the assembler, but if umcbuild is looking for the old *.dev files from MPLAB you might be SOL trying to use mplabx.
    On my system I have
    DB=d:\program files\microchip\mplab IDE\device
    which is where the old mplab *.dev files were/are located on my setup. MPLABX doesn't have these files anymore, or if it does they're buried deep inside some .jar file that I've never found.
    You might just be forced to install MPLAB.
  1. Amicus shields
    By Bruce in forum PBP & Amicus18
    Last Post: - 30th July 2011, 23:06
  2. AMICUS 18 Section
    By charudatt in forum Forum Requests
    Last Post: - 17th July 2011, 11:03
  3. Amicus Name
    By Charles Linquis in forum PBP & Amicus18
    Last Post: - 31st May 2011, 06:01
  4. Amicus 18 Review
    By lester in forum General
    Last Post: - 10th June 2010, 08:58
