MEProg Bootloader Software
Results 1 to 5 of 5
    Mar 2017
    Default MEProg Bootloader Software
    We have Pic Basic Pro installed.
    We have plenty of PIC dip chips.
    How do I get the bootloader?
    Dec 2010
    Default Re: MEProg Bootloader Software
    Are you sure you want a bootloader? It sounds like you just want a programmer, and you will need one in any case, even if just to install the bootloader.
    It's also bad form to start threads asking the same question all over the place. We all read all the sections - the sections are there mostly to help folks reading about a particular topic.
    Mar 2017
    Charlie
    "Are you sure you want a bootloader?"
    It's coming into focus here.
    We need the hardware so that a PIC on a breadboard will program just like MELABS D-Stick and Experimenter boards.
    The 'software programmer' built in to PBasic will do the rest I believe.
    "It's also bad form to start threads asking the same question all over the place"
    My apoligies. Got excited finding forum. Finding PICBasic for that matter.
    Email 'Reply in Forum' have been going to Spam folder. I will fix it.
    Oct 2009
    As mentioned in the other thread, you need a PIC that supports the use of a bootloader, you need a PIC programmer to be able to first program the PIC with the bootloader. There are plenty of PIC programmers around, as well as schematics on the internet if you wanted to build your own.
    Mar 2017
    "if you wanted to build your own"
    The JDM and David Tait serial programmers are pretty interesting.
    Found WXPic software. Winpic guy says that's updated version of his.
    It is. It looks real good.
    We have Olimex PIC-PG1.
    Working on getting it running.
  1. Windows 8 - downloaded PBP3 but meprog is nowhere to be found
    By vintagecarguy in forum mel PIC BASIC Pro
    Last Post: - 18th March 2013, 16:36
  2. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 22:25
  3. meProg configuration vs setting fuses in code
    By AndrewC in forum General
    Last Post: - 10th June 2008, 15:00
  4. Replies: 3
    Last Post: - 26th November 2006, 22:47
  5. Bootloader software
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 29th June 2005, 18:58
