That's because PicBasic is not designed to program chips via a bootloader by default.
Firstly you need a PIC that supports the use of a bootloader, which I don't think the 12F683 does as it can't self write to its flash memory.
Once you have a PIC that does support a bootloader, you need a PIC programmer that supports the PIC you want to use to write the bootloader code into the PICs memory. Then you can use whatever application to communicate with the PIC via it's UART (serial or USB depending on the chip's built in functions and hardware).
