Student Version Chips
Results 1 to 4 of 4
    Mar 2017
    Default Student Version Chips
    We are trying to get one off the list of supported chips that
    will work on our Olimex protoboard.
    https://www.olimex.com/Products/PIC/...PIC-P40-20MHz/
    I see one problem. Does Pro Basic only support 4mhz clock speeds?
    Looks like we're headed to breadboarding first chip on list. 12F683.
    Will be programming it with clone PICKit 3 and then serial progamming with PIC Basic.
    Default Re: Student Version Chips
    PBP supports 14 different oscillator speeds, check the manual, section 2.3.1.
    Mar 2017
    Thank you.
    What are the steps to have bootloader on the 12F683 or another chip that supports a bootlader?
    Haven't seen anything about that in manuals.
    Oct 2009
    That's because PicBasic is not designed to program chips via a bootloader by default.
    Firstly you need a PIC that supports the use of a bootloader, which I don't think the 12F683 does as it can't self write to its flash memory.
    Once you have a PIC that does support a bootloader, you need a PIC programmer that supports the PIC you want to use to write the bootloader code into the PICs memory. Then you can use whatever application to communicate with the PIC via it's UART (serial or USB depending on the chip's built in functions and hardware).
  1. New PBP version - Gold version - Is it really worth it?
    By financecatalyst in forum General
    Last Post: - 8th October 2011, 02:34
  2. Student Final Project Need help
    By marco in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 19:12
  3. help with version 2.04
    By mxjf in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 05:01
  4. Student Project
    By aggie in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 09:56
  5. Shall we see a new version soon?
    By Bulman in forum mel PIC BASIC Pro
    Last Post: - 28th September 2004, 17:18
