Bootloaders and configs
Results 1 to 10 of 10
    Sep 2009
    Default Re: Bootloaders and configs
    Hex isn't problem. You can have configs in hex, but application that parse hex file should ignore configs and send only program and eeprom to bootloader. I post simple bootloader code somewhere on forum.
    The 16F series isn't even capable of reprogramming their own CONFIG word(s). For example, on the 16F819, the CONFIG word is at address 2007h and the datasheet says
    It is important to note that address 2007h is beyond the
    user program memory space which can be accessed
    only during programming.
    It also says
    Accessing a location above the
    physically implemented address will cause a
    wraparound.
    So if you TRIED to write to the CONFIG word you'd actually write to another location possibly corrupting the program.
    So yeah, you need to be carefull of what you're doing. I'm curious, the 16F819 doesn't have an UART, are you planning to use bitbanged serial for the download or are you going to inject the new firmware image in some other way (SPI, I2C)?
    Oct 2012
    Hi Team,
    Pedja089 I will search for your post, thank you.
    Henrik, I will have a friend of mine, who knows more assembly than I do, helping with this project.
    We are trying to make small changes, to fit our needs, to this project I found in my research:
    http://pygmy.utoh.org/pikme/
    Right now we are collecting as much information as we can to make sure we are taking the right path.
    Thank you for your advices and interest.
    Nick
  1. Replies: 7
    Last Post: - 24th September 2014, 17:27
  2. recommendations for secure bootloaders
    Last Post: - 29th August 2014, 00:31
  3. 18F6310 configs
    Last Post: - 10th January 2012, 06:47
  4. 18F4520 Configs
    Last Post: - 10th June 2010, 22:18
  5. Getting Configs straight
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 24th January 2007, 04:16
