Loader_used 1
Results 1 to 4 of 4
Thread: Loader_used 1
    sebstien.decorm's Avatar
    sebstien.decorm Guest
    Default I understand..
    Ok I found why most of bootloader don't work with the "LOADER_USED 1" command.
    Because the melabs bootloader start at the end of the prog instead of the first 0x200 first byte :
    it start with GOTO 0x7e00
    so I have to modify my bootload to be at the end of the pic , because the pbp work always at the begin ..
    If the bootloader is located before the program, you can use this define.
    DEFINE RESET_ORG 200h
    <br><br>
    Juan Rios's Avatar
    Juan Rios Guest
    Default Bootloader for 16Fxx
    Hello, I had the same problem with the bootloader and the Reset_Org suggestion worked great for me, but it's only supported in PBP for 18Fxx. When I tried same with a 16F874 I found that PBP ignores the DEFINE and fills low memory with its own routines. I want to put my bootloader in the bootloader area to be able to protect it, so placing it in high memory is not a good solution.
    I'm using PBPW V2.46 and MPASM V3.90 under MPLAB V7.01. My bootloader is based on Microchip's AN851.
    Could someone give me a hint? Thanks in advance.
    Juan Rios
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
