That worked Awesome! Thank you so much! I don’t know why I was thinking I was running at 4GHz, but even at 8GHz I didn’t think it would sound that good. Perfect!
Jim
I gave this a try, 10F222 at 8MHz. Generating roughly 300-3000Hz with the following code:
   __config _IOFSCS_8MHZ & _WDT_OFF & _MCLRE_OFF & _CP_OFF
DEFINE NO_CLRWDT 1             ' Forces manual use of CLRWDT
GPIO = %0000
TRISIO = %00111101
ADCON0   = %01000001	       ' GPIO 0 = Analog, ADC Enabled
SPK VAR GPIO.1
Trigger VAR GPIO.2
GO_DONE  VAR  ADCON0.1
SomeValue CON 75
SomeConstant CON 12
IF Trigger THEN
  GO_DONE = 1
  SPK = 1                ' Set pin high
  WHILE GO_DONE : WEND   ' AD conversion will always take the same amount of time
  PAUSEUS SomeValue + (ADRES * SomeConstant)
  GO_DONE = 1
  SPK = 0                ' Set pin low
  PAUSEUS 16 + SomeValue + (ADRES * SomeConstant)
  ' The 16 above is to make the dutycycle closer to 50% than what it was
  ' without it. I'm quite surprised such a high number was needed and I'm
  ' not sure why that is.
Goto Main
Removing the PAUSEUS statements altoghether brings the frequency to 47kHz so there's plenty of margin.
