What range of frequencies are you aiming to generate. I see from your SOUND statements that it would equal notes 50 to 113 but I don't know what that translates to in actual frequency (and are those numbers critical?
Like Art says, all the SOUND command is doing is toggling a pin. You can do that too and you make the ADC do the conversion while waiting to flip the pin. Something like this perhaps (not tested):
SomeValue CON 250
SomeConstant CON 4
IF Trigger THEN
SPK = 1 ' Set pin high
GO_DONE = 1
WHILE GO_DONE : WEND ' AD conversion will always take the same amount of time
PAUSEUS SomeValue + (ADRES * SomeConstant)
SPK = 0
GO_DONE = 1
Goto Main
