High speed pic scaler for Survey meter for PIC16F627A translation to PIC18F2855?
Results 1 to 8 of 8
    Seoullasers's Avatar
    Seoullasers Guest
    Post Re: High speed pic scaler for Survey meter for PIC16F627A translation to PIC18F2455?
    1) I think I goofed in the title. Should be PIC18F2455
    link here : http://www.microchip.com/wwwproducts/en/en010273
    2) What I gave to you was the commented release of the code. It doesn't address the pins. yes right...
    3) ECIO28P http://www.matrixtsl.com/resources/f.../ECIO-60-2.pdf see page 4.
    4) I'll attach the .bas files. to the thread to have a look at. I am totally unsure if this sketch will work.
    I don't have a PIC16F627A to look at to make a judgement call.
    Welcome aboard seoullasers
    The chip on the ECIO28P is a 18F2455. Found here : http://www.matrixtsl.com/webshop/28-...c-18-ecio.html
    I haven't looked in detail at the differences between your suggested code and the actual hardware you wish to use. However, a few re-assignments may be needed to get this to work. The code looks good enough though not properly indented.
    You haven't mentioned your skill level working with PIC in general. For someone who may be just getting into PIC programming, it may be challenging to port code to another platform.
    I've done a tiny bit of work with pics... very basic stuff. I am usually dealing with ATMega, ARM and some STM32... This programming language is completely new. I was hoping someone here could help me with the code.
    IF there is anything useful for you in these attached files.
    thanks..
    ScalerCST7r.basScaler11.basScaler1.bas
  1. High Speed Oscillator question
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 9th July 2012, 10:29
  2. Pic based Wind Speed meter
    By Bobbo_ZA in forum mel PIC BASIC Pro
    Last Post: - 1st November 2011, 15:14
  3. Replies: 0
    Last Post: - 7th August 2008, 09:02
  4. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
  5. Need help, high speed D/A converter, see code
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 01:33
