Unable to program 18F67J94
Results 1 to 3 of 3
    Default Unable to program 18F67J94
    Recent upgrade to PBP3 and it is running perfectly with another J-chip(18F26J53). Not so with the 18F67J94. Click program and get "Target device does't match.....)" Tried the usual things all OK. I Have R-checked all traces and all voltages are normal. This chip was mounted on a inline DIP breakout board. No currents above 15-20mA. observed. Is there anyone out there that can confirm that they have used PBP3 with this chip and have had no problems. I may have over looked something or have a couple of dead chips? Thanks.
    Mar 2017
    Default Re: Unable to program 18F67J94
    There's alot of things it could be.
    Unlikely there's anything wrong with a new chip from Microchip or any of the big distributors.
    Check pinout of chip against breakout board.
    Put old chip back in and make sure nothing changed on board.
    Miami, Florida USA
    The melabs website shows that PBP3 supports that chip. I have never seen a defective PIC in all the years I've programming them. More than likely that you are not setting the registers correctly. Check the settings again. The problem might be there.
    Anonymous
  1. Unable to execute mpasmwin
    By oldmainframer in forum General
    Last Post: - 18th December 2016, 00:01
  2. unable to program
    By jerrico in forum mel PIC BASIC
    Last Post: - 16th April 2011, 12:56
  3. unable to access any ports
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 31st August 2010, 14:27
  4. unable to fit variable?
    By MOUNTAIN747 in forum General
    Last Post: - 4th February 2010, 21:20
  5. Unable to compile..Pls Help
    By DragonBall_6 in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 16:17
