MCS is Crashing
Results 1 to 40 of 44
Thread: MCS is Crashing
    Default Re: MCS is Crashing
    I've always used default MCSP settings.
    My laptop used is a HP Pavillion i5 Intel/nVidia.
    I'll try later typing a long-winded comment and see how that goes.
    Nope, long-winded comments, a DEFINE OSC 10 thrown in, more comments, no problem.
    Perhaps I'm not approaching this with the same attack...
    If this was a "sure thing" that ALWAYS happened, it would be pretty easy to resolve. However, my experience is it's very hit and miss - hence I don't believe a crash can be "forced", there are other undetermined variables involved, but... again... because it ALWAYS when I'm typing, I believe that says something. It can sit idle for DAYS and nothing happens. I'm wondering if others who are experiencing this can avoid crashes by trying this change, thereby contributing to the validation of the theory - not try to FORCE another crash when it's unpredictable and not a "sure thing".
    Well then, I guess I'll just keep an eye open and report back f anything happens. But MCSP has never bombed on me in over a year on this laptop.
    I honestly cannot see how graphic drivers have anything to do with data entry, especially in software that emulates Notepad (no special characters).
    But then again, my specialty was mainframe programming. I only program PCs when I sleep at the Holiday Inn.
    Just crashed, not using italics. So much for that theory. HOWEVER, it still crashed while I was typing in a comment field, which has always been the case for me.
    Apr 2011
    Welches, Oregon
    I find it highly unlikely that it has anything at all to do with PBP (other than the obvious interruption to it). If so, I would think every user (having the exact same files loaded) would have the exact same issue - and, one would suppose, it would not be difficult to duplicate for the same reasons. I think that it must be some interaction with another process or service - perhaps a background application using the com port, USB access or internet connection- there are dozens of running programs active from the moment the power is turned on.
    Has anyone disabled the files that start at power up? It is one of my pet peeves is manufacturers who seem to believe they own all of my computer's resources because I use one of their applications. I have found HP, Nvidia, and Adobe to be nearly criminal in their dis-care, but they are far from the only culprits. Starting with a minimal set-up and adding one line or application at a time may help to isolate what resource is causing the issue?
    crashed again this morning, while typing a comment (same as always). Name:  mcs crash notification.jpg
    Faulting application name: CodeStudioPlus.exe, version: 5.0.0.5, time stamp: 0x2a425e19
    Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
    Exception code: 0x00000000
    Fault offset: 0x00000000
    Faulting process id: 0x1fb0
    Faulting application start time: 0x01d2d7bae18ebaac
    Faulting application path: C:\Program Files (x86)\Mecanique\MCSPX\CodeStudioPlus.exe
    Faulting module path: unknown
    Report Id: 1f0308d8-43b0-11e7-a3d0-ac72892a9ffd
    and 23 seconds later,
    Faulting module name: ntdll.dll, version: 6.1.7601.23796, time stamp: 0x59028db3
    Exception code: 0xc0000025
    Fault offset: 0x000904b0
    Faulting module path: C:\Windows\SysWOW64\ntdll.dll
    Report Id: 2d149eb5-43b0-11e7-a3d0-ac72892a9ffd
    Any further suggestions?
    This is the ONLY program that halts and displays an error, ALWAYS when typing in comments.
  1. MicroCodeStudioPlus keeps crashing.
    By c_moore in forum PBP3
    Last Post: - 20th February 2018, 13:18
  2. Crashing 16F628 Code
    By hhaplant in forum mel PIC BASIC Pro
    Last Post: - 24th March 2012, 09:40
  3. Crashing LCD
    By George in forum Off Topic
    Last Post: - 16th January 2012, 21:05
  4. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 16:33
  5. Crashing program
    Last Post: - 6th April 2006, 02:57
