Measuring duty cycle of short duration pulses with long period
Results 1 to 13 of 13
    Default Re: Measuring duty cycle of short duration pulses with long period
    Hmm, if maximum period is 20ms then the timer would need to be reconfigured but Bill said: variable frequency (5-55hz = 600-6600rpm). At 5Hz the period is 200ms, at 55Hz the period is 18ms. So the the timer must be able to measure at least 200ms. Or am I doing a stupid mistake somewhere?
    Oct 2012
    No Henrik, as usual I'm wrong.
    Sorry for false alarm.
    Nick
    Jun 2005
    West Australia
    Hi Henrik,
    Thanks for your help and code sample, I'll use this as a guide for other timing tasks if it doesn't work for this particular role.
    I understand the ratio calcs for Duty Cycle and have done this a few times before, but with gasoline injectors where their on time is proportional i.e. let's say max rpm limits maximum duty cycle to 20ms. In such circumstances DC is easy - 10ms = 50%, 20 = 100%, etc.
    But with modern diesel common-rail injectors (extremely high fuel pressure so inj open times are in microseconds) the ratio between on-times and period blows out so much to be unusable in normal math for DC. It doesn't need to be exact but does need to be reliable and repeatable as DC will form an axis in a lookup table to control vnt turbo characteristics and boost curve via a PWM solenoid valve. I will start a different thread soon and request suggestions on how to do 3D mapping.
    It's a catch-22 situation in that I don't know what a particular engine's max DC is unless fully loaded on a dyno and 'scope measurements are taken - expensive. In a gasoline engine this isn't needed due conventional math taking care of it. I can make an educated guess and set the diesel's max DC as 1000us (typical full load) then measure on-the-fly using this as the reference to derive some data as the engine is loaded - if it exceeds 100% then code could update the ref and store this along with the max pulse length... do you see another way?
    Kind regards,
    Bill
    OK, so you're not really interested in the actual dutycycle of the signal.
    You're interested in how long the pulse is relative to its maximum length and the pulse maximum length is NOT equal to the period of the signal (which would be 100% duty cycle by the standard definition).
    This means that the timer doesn't need to be able to resolve the complete period of the signal, only the maximum width of the pulse - and this is good because it increases your resolution substantially. All you need to do then is to capture the TMR1 value on the rising edge and then capture again on the falling edge, that's your actual width. Calculate percentage relative your maximum width.
    You could certainly guestimate the initial value (1000us) and the apply some "adaptive learning" to the code.
    (This was my $0BB8 post, yay)
    Jun 2005
    West Australia
    Hi Henrik,
    Yes, I think conventional DC doesn't apply here. Thanks for the confirmation of what needs to be done.
    Congrats on the milestone in postings - makes my $32 look fairly miserable in comparison
    Cheers,
    Bill
    Jun 2005
    West Australia
    Hi All,
    I've done some research and have found modern diesels have multiple fuel injection events such is the speed of the piezo injectors with extremes of fuel pressure to pass. Events typically number up to 5 but some documents suggest up to 8.
    So my goal has changed slightly whereby I now want to capture each of these events and sum their duration for maximum fuel injected and also record the longest pulse (if 5 events this is most likely the middle one). I can use tmr1 for capturing each pulse's duration but I want to limit recording of valid events to a 4ms window (triggered by first pulse edge) and am not doing too well manipulating tmr0 using Darrel's Instant Interrupts. I really need to embrace these and use more often...
    The full code (work in progress!) shows what I am trying to do but without success. As written Led2 pulses about 1hz and I only see a 4ms flash if the asm parts are commented out - but then pulse values are wild and erratic.
    How does one start and stop DT's Ints or is there a better way to control a 4ms window. All advice is greatly appreciated.
    Cheers,
    Bill
    '*  Name    : Pulses Timer.pbp        *
    '*  Date    : 25-02-17        *
    '*  Device  : 16F648A (4k code space).                                                              *
    '*  Version : 1.0        *
    '*  Notes 1 :  words with (PBP 3.0.6.4)  with thanks to Darrel Taylor for his ISR.                  *
    '*          : Uses DT's Instant Interrupts with Tmr0 for a 4ms window and Tmr1 for pulse duration.  *
    '*          : The code records multiple injection events within a 4ms window and combines all for   *
    '*          : total fuel time, also takes longest pulse and self adjusts reference duration if it   *
    '*          : exceeds current set DutyCycle value.  A low value first read from EEPROM allows early *
    '*          : updates to the LCD.  Updated value can be saved to EEPROM by pushbutton control.      *
    '*          : A switch sets expected polarity of the incoming pulses - normally high pulsing low as *
    '*          : measured at injector [usual] or normally low pulsing high at ecu output [possible].   *
    ' LCD     	PIC(F648A)          OTHER
    ' DB0-3   	No connection
    ' DB4     	PortA.0 (pin 17)
    ' DB5     	PortA.1 (pin 18)
    ' DB6     	PortA.2 (pin 1)
    ' DB7     	PortA.3 (pin 2)
    ' RS      	PortA.4 (pin 3)     10K pullup to 5v due Open Drain.
    '           MCLR    (pin 4)     10k pullup to 5v.
    ' RW      	Ground  (pin 5)
    ' Vdd     	5 volts (pin 14)
    ' Vss     	Ground  (pin 5)
    ' Vo      	                    20K LCD contrast potentiometer wiper (or ground).
    '       	PortB.0 (pin6)      Set button (10k pullup to 5v).
    ' 		    PortB.1 (pin7)	    + button (10k pullup to 5v).
    '		    PortB.2 (pin 8)     - button (10k pullup to 5v).  Hardware serial port Rx.
    '   (CCP1)	PortB.3 (pin 9)     Input for Pulses/Duty Cycle via 1k.
    '		    PortB.4 (pin 10)    Polarity of pulse switch - Pulled up.
    '		    PortB.5 (pin 11)
    '		    PortB.6 (pin 12)
    ' 		    PortB.7 (pin 13)    Debug in via 22k.
    '    Xtal   PortA.6 (pin 15)    Debug out via 1k.
    ' E  Xtal   PortA.7 (pin 16)
    '        CONFIGURE DEVICE
    ' The config can set RB0 or RB3 for CCP1 capture use. Confirm by viewing the fuses code box via the programmer.
        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    wsave   VAR BYTE    $70     SYSTEM      ' Save location for W
    ' -----[ Initialization ]------------------------------------------------------------------------------------------------
        CMCON = 7         	    ' Disable analog comparators.
        T1CON = 0               ' TIMER1: Clock Internal, Pre-scaler 1:1
    	Define 	OSC    4        ' Set Xtal Frequency
    ' Define LCD connections       Change these to match your LCD
        DEFINE  LCD_DREG        PORTA	' LCD Data Port
        DEFINE  LCD_DBIT        0		' Starting Data Bit
        DEFINE  LCD_RSREG       PORTA	' Register Select Port
        DEFINE  LCD_RSBIT       4		' Register Select Bit
        DEFINE  LCD_EREG        PORTA	' Enable Port
        DEFINE  LCD_EBIT        7		' Enable Bit
        DEFINE  LCD_BITS		4		' Data Bus Size
        DEFINE  LCD_LINES		2		' Number of Lines on LCD
        DEFINE DEBUG_REG PORTA      ' Port_A outgoing serial communication.
        DEFINE DEBUG_BIT 6
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 1         ' Debug mode: 0 = True, 1 = Inverted
    'Includes
    	Include "Modedefs.bas"      ' Mode definitions for Debug, Serin/out, Shiftin/out, Xin/out.
        INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
        INCLUDE "ReEnterPBP.bas"    ' Include if using PBP interrupts
            INT_Handler   TMR0_INT,  _ToggleLED2,   PBP,  yes
        INT_CREATE             ; Creates the interrupt processor
    ;    INT_ENABLE  TMR0_INT   ; enable Timer 0 interrupts.  [WJS] normally enabled here but not for this app. as it
    ENDASM                     ; is only enabled when required for the timing windows.
    ' OPTION_REG = %10010011    ; Prescale of 16 will give 4ms interrupt (8ms period).
     OPTION_REG = %10010010    ; Prescale of 8 will give 2ms interrupt (4ms period).
        Data "Pulses Timer",word 400 ' Next locn is 14.
    '        PIN ASSIGNMENTS, SYSTEM CONSTANTS, TEMPORARY VARIABLES
    ' Alias pins
    Set         var     PORTB.0     ' Set button.
    Plus        var     PORTB.1     ' + button.
    Minus       var     PortB.2     ' - button.
    SignalInput var     PORTB.3     ' Input pulses pin.
    Polar       var     PORTB.4     ' Polarity switch for output pin - normal high going low or normal low going high.
    LED2        var     PORTB.7     ' LED for Tmr0 testing.
    ' Variables
        PulseHigh1      var word    ' Width of 1st +ve going pulse, idling low.
        PulseLow1       var word    ' Width of 1st -ve going pulse, idling high.
        PulseHigh2      var word    ' Width of 2nd +ve going pulse, idling low.
        PulseLow2       var word    ' Width of 2nd -ve going pulse, idling high.
        PulseHigh3      var word    ' etc...
        PulseLow3       var word    '
        PulseHigh4      var word    '
        PulseLow4       var word    '
        PulseHigh5      var word    '
        PulseLow5       var word    '
        SumPulseHigh    var word    ' Sum of Widths of +ve going pulses, idling low.
        SumPulseLow     var word    ' Sum of Widths of -ve going pulses, idling high.
        DC100           var word    ' Value of 100% Duty Cycle for math calcs despite frequency.
        Dummy           var Word    ' For Div32 math.
        DutyCycle       var word    ' Percentage of pulse ratio wrt DC100.
        MaxPulse        var word    ' Max pulse measured - should always be the Main injection pulse.
        x               var word    ' Loop counter.
        Events          var byte    ' Number of inj pulses per cycle.
        Sign            var byte    ' + or - sign for serial indication of polarity.
        Window          var bit     ' Event window - limits time when pulses are valid. 1 = open, 0 = closed.
    ' Alias Definition
        T1ON    var T1CON.0
    ' Software/Hardware initialisation
        CLEAR
        TRISA = %00001111           ' PORTA I/O.
        TRISB = %10011111           ' RB3 as input for pulses, RB4 is polarity select switch.
        PortA.6 = 0                 ' Set low for serial debug idle state.
        read 12,word DC100          ' Read initial value of stored DutyCycle (start with 400).
        MaxPulse = 0                ' Reset count - can only get bigger from here.
        Events = 0                  ' Reset count.
        GOSUB ClearTimer
    First:      ' Operation when system first powered up.
    ' Load custom characters to LCD CGRam memory.
        LCDOUT $FE,64                           ' Set CGRam mode.
        LCDOUT $FE,$40,15,9,9,9,9,9,9,25        ' Cust Char #0 +ve pulse symbol.
        LCDOUT $FE,$48,25,9,9,9,9,9,9,15        ' Cust Char #1 -ve pulse symbol.
        LCDOUT $FE,1,$FE,2                      ' Exit CGRam mode, Clear screen and home cursor.
        goto Start                              ' Jump subs.
    ' Subroutines here in the first page...
    ClearTimer:
        TMR1L=0
        TMR1H=0
    AdjustDC100:
        for x = 0 to 99        ' 100 cycles.
        LCDOUT $FE,2,"DC 100% = ",dec4 DC100,"us"
        LCDOUT $FE,$C0,"    Set + -     "
        if plus = 0 then       ' + pushed.
            DC100=DC100+10     ' increment in 10us lumps.
            pause 50
            if Minus = 0 then  ' - pushed.
            DC100=DC100-10     ' decrement in 10us lumps.
            pause 50
        pause 100              ' .1*100 = 10 second loop.
            If Set = 0 then    ' Set is pushed.
            While Set = 0      ' If still pressed then wait -
            PAUSE 5            ' - until released.
            Wend
            write 12,DC100.lowbyte  ' Store new value in EEPROM.
            write 13,DC100.Highbyte ' Store new value in EEPROM.
            LCDOUT $FE,$C0," Stored okay... "
            pause 2000         ' Time to read it.
            return             ' Jump out once done.
        next
    ' Program area...
    Start:
    ' Check if buttons pushed.
        If plus = 0 then            ' Plus button pushed.
            While plus = 0          ' If still pressed then wait -
            Wend
            gosub AdjustDC100
        If Minus = 0 then           ' Minus button pushed.
            While Minus = 0         ' If still pressed then wait -
            Wend
            MaxPulse = 0            ' Reset Max.
    ' Check Polarity switch state.
        if polar = 1 then           ' Switch open - this pin sits high due pullup, expects high pulse.
            sign = "+"              ' expecting high pulse.
            LCDOUT $FE,2,1          ' Cust Char #1 +ve pulse Line 1 posn 1.
            goto GetHighs           ' Jump to routine.
        if polar = 0 then           ' Switch closed - this pin sits low, expects low pulse.
            sign = "-"              ' expecting low pulse.
            LCDOUT $FE,2,0          ' Cust Char #0 -ve pulse Line 1 posn 1.
            goto GetLows            ' Jump to routine.
    GetHighs:   ' Measure high pulses
        WHILE SIGNALINPUT = 0       ' Waiting for rising edge.
        WEND
    ' Start timers - a rising edge has been detected to get here.
    @    INT_ENABLE  TMR0_INT       ; Enable Tmr0 interrupts for 4ms window.
     Window = 1                     ' Open the pulse count window.
     while Window = 1               '
     T1ON = 1                       ' Start Pulse Timer tmr1.
        WHILE SIGNALINPUT = 1       ' Wait for next falling edge.
        WEND
     T1ON = 0                       ' Stop timer.
        Events = 1                  '
        PULSEhigh1.HIGHBYTE=TMR1H   ' Store results.
        PULSEhigh1.LOWBYTE=TMR1L    '
        if PULSEhigh1 > MaxPulse then
            MaxPulse = PULSEhigh1   ' Capture longest pulse.
        gosub Cleartimer            ' Reset Timer1 register (TMR1L, TMR1H).
    ' Capture additional high pulses
        WEND
     T1ON=1                         ' Start Pulse Timer tmr1.
        WEND
        Events = 2                  '
        PULSEhigh2.HIGHBYTE=TMR1H   ' Store results.
        PULSEhigh2.LOWBYTE=TMR1L    '
        if PULSEhigh2 > MaxPulse then
            MaxPulse = PULSEhigh2   ' Capture longest pulse.
        WEND
        WEND
        Events = 3                  '
        PULSEhigh3.HIGHBYTE=TMR1H   ' Store results.
        PULSEhigh3.LOWBYTE=TMR1L    '
        if PULSEhigh3 > MaxPulse then
            MaxPulse = PULSEhigh3   ' Capture longest pulse.
        WEND
        WEND
        Events = 4                  '
        PULSEhigh4.HIGHBYTE=TMR1H   ' Store results.
        PULSEhigh4.LOWBYTE=TMR1L    '
        if PULSEhigh4 > MaxPulse then
            MaxPulse = PULSEhigh4   ' Capture longest pulse.
        WEND
        WEND
        Events = 5                  '
        PULSEhigh5.HIGHBYTE=TMR1H   ' Store results.
        PULSEhigh5.LOWBYTE=TMR1L    '
        if PULSEhigh5 > MaxPulse then
            MaxPulse = PULSEhigh5   ' Capture longest pulse.
     wend
        sumpulsehigh = pulsehigh1 + pulsehigh2 + pulsehigh3 + pulsehigh4 + pulsehigh5
        dummy = MaxPulse*100        ' Perform the multiply ready for Div32.
        DutyCycle = div32 DC100     ' Calculate wrt stored value.
    ' ### NB debug affected by interrupts!
    'debug "Pol ",sign,", MaxPulse ",dec4 MaxPulse,"us, Events ",#Events,13
        LCDOUT $FE,2,0," Inj ",dec4 maxpulse,"us Max"  ' Write LCD line 1.
        goto ShowMore               ' Jump GetLows.
    GetLows:    ' Measure low pulses
     while Signalinput = 1          ' Waiting for falling edge.
     Wend
    ' Start timers - a falling edge has been detected to get here.
    @    INT_ENABLE  TMR0_INT       ; Enable Tmr0 interrupts for 5ms window.
     while Window = 1               ' ### is the first line needed?
     T1ON = 1                       ' Start timer1.
        WHILE SIGNALINPUT = 0       ' Wait for next rising edge.
        WEND
     T1ON = 0                       ' Stop Timer.
        Events = 1                  '
        PULSElow1.HIGHBYTE = TMR1H  ' Store result.
        PULSElow1.LOWBYTE = TMR1L   '
        if PULSElow1 > MaxPulse then
            MaxPulse = PULSElow1    ' Capture longest pulse.
    ' Capture additional low pulses
        WEND
        WEND
        Events = 2                  '
        PULSElow2.HIGHBYTE = TMR1H  ' Store result.
        PULSElow2.LOWBYTE = TMR1L   '
        if PULSElow2 > MaxPulse then
            MaxPulse = PULSElow2    ' Capture longest pulse.
        WEND
        WEND
        Events = 3                  '
        PULSElow3.HIGHBYTE = TMR1H  ' Store result.
        PULSElow3.LOWBYTE = TMR1L   '
        if PULSElow3 > MaxPulse then
            MaxPulse = PULSElow3    ' Capture longest pulse.
        WEND
        WEND
        Events = 4                  '
        PULSElow4.HIGHBYTE = TMR1H  ' Store result.
        PULSElow4.LOWBYTE = TMR1L   '
        if PULSElow4 > MaxPulse then
            MaxPulse = PULSElow4    ' Capture longest pulse.
        WEND
        WEND
        Events = 5                  '
        PULSElow5.HIGHBYTE = TMR1H  ' Store result.
        PULSElow5.LOWBYTE = TMR1L   '
        if PULSElow5 > MaxPulse then
            MaxPulse = PULSElow5    ' Capture longest pulse.
    '    Window = 0                  ' Close the pulse count window.  #### Testing - Int should do this.
     wend
        sumpulselow = pulselow1 + pulselow2 + pulselow3 + pulselow4 + pulselow5
        dummy = maxpulse*100        ' Perform the multiply ready for Div32.
    ' ### NB affected by interrupts!
    'debug "Pol ",sign,", MaxPulse ",dec4 MaxPulse,"us, ",#Events," Events, SumPulseLow = ",#sumpulselow,13
        LCDOUT $FE,2,0," Inj ",dec4 PULSElow3,"us Max"  ' Write LCD line 1.
    ShowMore:
        LCDOUT $FE,$C0,"DC",DEC2 DutyCycle,"% ",dec4 DC100," ",dec5 MaxPulse    ' Write LCD line 2.
        pause 500                   ' Time to read.
        goto start
    '---[TMR0 - interrupt handler]-------------
    ToggleLED2:
        Window = 0                  ' Close the window for pulse counting.
        TOGGLE LED2                 ' LED2 flashes, timed by TMR0.
    @    INT_DISABLE  TMR0_INT      ; Disable Tmr0 interrupts ready for next window.
    @ INT_RETURN                    ; Return to point where interrupt took place.
    an alternative approach could be to use a chip with timer1 gate control.
    if the timer gate was connected to the injector signal and the timer read and reset at a metered rate
    the count would be directly proportional to the injector ontime [effectively a digital integrator].
    it should not be too difficult to find a suitable timer clock rate and integration period to suit.
  1. Count Pulses and duration
    Last Post: - 13th February 2014, 22:04
  2. Measuring Period of a pulse
    By c_moore in forum mel PIC BASIC Pro
    Last Post: - 17th February 2012, 05:15
  3. Measuring duty cycle when it can be 0 to 100.
    Last Post: - 3rd December 2011, 18:24
  4. Pin max current - short duration?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 12:53
  5. Measuring Period & Hz
    By MaurI in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 04:03
