795us over 45ms is 1.76%, not 17.6% as I wrote earlier.
Anyway, here's a piece of code that may do what you want. It uses TMR1 and CCP1 to measure the input signal, calculates the dutycycle and displays it with .1% resolution. It compiles for a 16F88 but I have not tested it.
' Program expects 4MHz oscillator.
' CCP1 inputpin is either RB0 or RB3 depending on the CCPMX bit in CONFIG.
CapRise CON %00000101		' Value to configure CCP1 for capturing every rising edge
CapFall CON %00000100		' Value to configure CCP1 for capturing every falling edge
CCP1IF 	VAR PIR1.2		' Alias to CCP1 Interrupt flag
Period 	VAR WORD
Width 	VAR WORD
Duty 	VAR WORD
Dummy	VAR WORD
T1 	VAR WORD
T2 	VAR WORD
T3 	VAR WORD
T1CON = %00100001		' TMR1 clock from FOsc/4, Prescaler 1:4
    ' Capture the the time where the pulse starts
    CCP1CON = CapRise
    CCP1IF = 0
    WHILE !CCP1IF : WEND
    T1.HIGHBYTE = CCPR1H : T1.LOWBYTE = CCPR1L
    ' Capture the time where the pulse ends
    CCP1CON = CapFall
    CCP1IF = 0
    T2.HIGHBYTE = CCPR1H : T2.LOWBYTE = CCPR1L
    ' Capture the time where the period ends (which is when the next pulse starts)
    CCP1CON = CapRise
    CCP1IF = 0
    T3.HIGHBYTE = CCPR1H : T3.LOWBYTE = CCPR1L
    Width = T2 - T1
    Period = T3 - T1
    Dummy = Width * 1000
    Duty = DIV32 Period
    ' Duty is now in units of .1% (111 = 11.1%)
    LCDOUT $FE, 1, "W:", DEC Width, " P:", DEC Period
    LCDOUT $FE, $C0, "Duty:", DEC Duty/10, ".", DEC Duty//10, "%"
Goto Main
