LCDout question
Results 1 to 10 of 10
Thread: LCDout question
    MikeTamu's Avatar
    MikeTamu Guest
    Default LCDout question
    Is there any way I can use the following pinouts with LCDout? I realize that I should use one port and either the upper or lower 4 bits...
    RS: Portb.7
    R/W: Ground
    E: Portb.5
    DB4: Portb.4
    DB5: Portb.3
    DB6: Portb.2
    DB7: Portb.1
    I'm stuck with a fabricated board that is connected in this manner. Is there any way I can go in and 'edit' in order to get the LCDout command to work with this configuration?
    Thanks.
    DaveB's Avatar
    DaveB Guest
    Default RE: LCDOut
    Allo There,
    Yes you can define pins as follows :-
    DEFINE LCD_EREG PORTB ' Define enable port
    DEFINE LCD_EBIT 1 ' Set up enable bit
    DEFINE LCD_RSREG PORTB ' Define register select port
    DEFINE LCD_RSBIT 2 ' Set up register select bit
    DEFINE LCD_RWREG PORTB ' Define read/write port
    DEFINE LCD_RWBIT 3 ' Set up read/write bit
    DEFINE LCD_DREG PORTB ' Define data port
    DEFINE LCD_DBIT 4 ' Set up data bit
    DEFINE LCD_COMMANDUS 2000 ' Set Command Delay Time 2mS
    DEFINE LCD_DATAUS 50 ' Set Data Delay Time 50uS
    Have just started myself in the last week, got this working with a 16F873A and Powertip PC1602-H LCD module. You'll just need to alter this a bit to match your outputs and put it after any includes.
    Cheers
    MikeTamu's Avatar
    MikeTamu Guest
    Thanks, I am aware of the LCD defines. I was actually wondering if I could change each individual data port. For example I don't have the data ports starting on Portb.0, but instead port portb.1. Also, the data ports are in backward order that they are supposed to be corresponding to portb.1,portb.2,portb.3, and portb.4.
    So, I need to be able to address each individual data port to a different port than standard. Is this possible?
    If not, is it possible to make my own Hitachi commands to do this instead?
    No you cannot do that. Only select 4/8 bit, and from 4 bits high port or low port bits (that is 0-3 or 4-7).
    Mar 2005
    Iowa, USA
    Quote Originally Posted by TFM
    The LCD may be connected to the PICmicro MCU using either a 4-bit bus or an 8-bit bus. If an 8-bit bus is used, all 8 bits must be on one port. If a 4-bit bus is used, the top 4 LCD data bits must be connected to either the bottom 4 or top 4 bits of one port. Enable and Register Select may be connected to any port pin. R/W may be tied to ground if the LCDIN command is not used.
    I thought it might have to do with the amount of current the lcd draws and how much the micro can take, but I could be wrong. Looks like you might have to cut some traces, and reroute with with "wires of shame".
    MikeTamu's Avatar
    MikeTamu Guest
    Well, I know the hardware (PIC18F252) is capable of running the LCD with my current setup. I designed the board with a Dios 28 pin microcontroller http://www.kronosrobotics.com/xcart/...roductid=16169 which is simply a PIC18F252 with a built in Basic compiler in one package. Kronosrobotic's Basic compiler has no problem in allowing any port on the MCU to be used for any pin on the LCD. I have my current configuration working in front of me with the Dios 28 mcu.
    However, for economic issues, I wanted to be able to switch to PBP. So, if the hardware permits my configuration, why doesn't PBP allow it? I assume MElabs wants a robust compiler, so I am not sure why there is not provisions in the compiler to allow LCD pin switching on permitting PICs.
    I guess I will have to write my own Hitachi LCD interface. I don't know what other options I have at this point.
    Feb 2004
    Germany
    MikeTamu,
    PBP does allow it,
    but you'll have to write your own "LCDOUT" Routine.
    See this thread
    regards
    Ralph
    MikeTamu's Avatar
    MikeTamu Guest
    Thanks, somehow I missed this thread in my search.
    Thinking more on the matter I found a solution that has been glaring me in the face this whole time. I can just edit some wires on the cable going to my lcd screen, and thus rename ports. Luckily I happen to get at least the upper 4 bits of portb on my interface.
    However, I am still interested in making a user friendly 'all-in-one' lcdoutX routine for future problems if they come up.
    Feb 2004
    Germany
    Quote Originally Posted by MikeTamu
    ...However, I am still interested in making a user friendly 'all-in-one' lcdoutX routine for future problems if they come up.
    Well, if it just a single shot (on an existing board) I would spend $2 and use another PIC as "serial backpack" for the LCD. (and free up some PIC Pins)
    Or rewire some pins.
    If we are talking about higher quantity I would design the Hardware to meet the requirements of my development tools in the first place.
    regards
    Ralph
    MikeTamu's Avatar
    MikeTamu Guest
    Correct.
    Unfortunately, I was not introduced to PBP until after this board was designed. The board was designed with a 3rd party brand microcontroller which is a repackaged PIC.
    It is low quantity and I have learned a valuable lesson here. I think for now a cable fix will suffice.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
