Problems with 18F458
Results 1 to 19 of 19
    Tallinn, Estonia
    May-be your clock speed is too high? PLL ON perhaps?
    Try simulating your code in MPLAB. If this works OK, it's something in hardware. If not, you'll find the bug quickly.
    I was just looking at your picture an couldn't help but notice the leads coming for the crystal. Shouldn't there be a empty space in between the pins. It looks like the pins are spaced at 0.100". It might be just the picture but I think the crystal is actually 0.200" pin spacing.
    My 2 cents... the crystal is really to far of the PIC, and try to remove both capacitor... breadboard capacitance
    I actually found running 22pF with our PIC's caused us loads of troubles. Things would reset all the time, corrupt displays and sensors. Removed the capacitors and everything works fantastic now. Scope the ocsillator output and noticed the capacitors were actually causing a lot of noise.
    Post
    100ms delay before you initialize your display could be too short. Many displays needs alot more. Try a couple of seconds and see if that makes it work.
    Aug 2005
    Unhappy
    No, I tried everything, removed the caps, set the most of the conf. bits to be negative, moved the osc. closer, increased the init delay (though it has worked well with 100 with the same display but a PIC16F84)....nothing helps, it still writes "!" in the start of the first line instead of the "Hello world!"
    Aug 2005
    Btw. here is a picture of my cfg.
  1. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  2. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 14:38
  3. Problems with PORTD on 18F658
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 18:32
  4. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
  5. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 22:45
