Problems with 18F458
Results 1 to 19 of 19
    What does your code look like? What pins is the LCD connected to? What are you using for an oscillator?
    Aug 2005
    I use a 4 Mhz crystal as osc. and I use PORTB as output, this is what my code looks like, I have included the library for LCD in the txt file:
    LIST p=18F458 ;tell assembler what chip we are using
    include "p18f458.inc" ;include the defaults for the chip
    ERRORLEVEL 0, -302 ;suppress bank selection messages
    cblock 0x20 ;start of general purpose registers
    ;LCD
    count ;used in looping routines
    count1 ;used in delay routine
    counta ;used in delay routine
    countb ;used in delay routine
    tmp1 ;temporary storage
    tmp2 templcd ;temp store for 4 bit mode
    templcd2
    endc
    LCD_PORT Equ PORTB
    LCD_TRIS Equ TRISB
    LCD_RS Equ 0x04
    LCD_RW Equ 0x06
    LCD_E Equ 0x07
    ;--------Program-------------------
    SetPorts
    movlw 0x00 ;make all pins outputs
    movwf LCD_TRIS ;wait for LCD to settle
    call Delay100
    call LCD_Init ;setup LCD
    call LCD_CurOff
    ld
    call LCD_Line1
    movlw 'H'
    call LCD_Char
    movlw 'e'
    call LCD_Char
    movlw 'l'
    call LCD_Char
    movlw 'l'
    call LCD_Char
    movlw 'o'
    call LCD_Char
    movlw ' '
    call LCD_Char
    movlw 'W'
    call LCD_Char
    movlw 'o'
    call LCD_Char
    movlw 'r'
    call LCD_Char
    movlw 'l'
    call LCD_Char
    movlw 'd'
    call LCD_Char
    movlw '!'
    call LCD_Char
    movlw '!'
    call LCD_Char
    movlw '!'
    call LCD_Char
    endprg goto endprg
    include <lcd.lib>
    Feb 2004
    Germany
    Russian,
    Do you have a pullup resistor on MCLR ?
    And hey, this is a PICBASIC Forum !
    regards
    Ralph
    Sorry but assembly is greek to me.
    Tallinn, Estonia
    Did you configure your 18f458 correctly? Especially LVP_OFF! This was the mistake, i made.
    Here is my code, check for the LCDPUTCHAR routine.
    Aug 2005
    I'm sorry, I know that this is a PIC Basic forum thats why I hadn't posted my code In the first thread. Yes, I have a pullup on MCLR, and LVP is off. Here I have a picture of what my screen shows when my program tries to write "Hello world!!!"
    Tallinn, Estonia
    May-be your clock speed is too high? PLL ON perhaps?
    Try simulating your code in MPLAB. If this works OK, it's something in hardware. If not, you'll find the bug quickly.
  1. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  2. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 13:38
  3. Problems with PORTD on 18F658
    By blainecf in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 17:32
  4. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 14:38
  5. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 21:45
