MCU seset and stop
Results 1 to 6 of 6
    Oct 2009
    Default Re: MCU seset and stop
    I think Charlie is right, but the code does seem to read correctly to a degree, but I think the resetting may because the config is only setting the speed of the processor, no other options have been set which to me might be the cause as to the resetting of the PIC. But then I use PBP 2.60c and this config statement looks different so I guessing the OP is using PBP3, so maybe this thread needs moving to the correct section ?
    Also I have to ask
    i var word
    for i = 1 to 10
    PORTC.0 = 1
    PORTC.0 = 0
    pause 200
    next i
    Why use a word variable for i when it's only running 10 cycles of the for next loop. Defining it as a byte would be fine
    What resistance are you using for the reset line? Also is the power supply solid?
    EN82fn
    not to mention
    define LCD_Bits 4 ' Set LCD Bus size(4 or 8 Bits)
    define LCD_BITS 4 ' Set LCD Bus size(4 or 8 Bits)
  1. How do I stop HPWM
    By DonLuis in forum General
    Last Post: - 15th September 2012, 12:15
  2. Defining MCU with MPASM
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 24th May 2007, 14:16
  3. Why does the clock stop?
    Last Post: - 29th May 2006, 16:36
  4. Too Simple To just Stop!
    By Homerclese in forum mel PIC BASIC
    Last Post: - 16th October 2005, 22:39
  5. Stop program
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 30th March 2004, 15:57
