How can i control pic input pins order?
Results 1 to 6 of 6
    tanero's Avatar
    tanero Guest
    Answer for CocaColaKid ;
    yes i want to store the number of buttons while 1 is working. After release 1 , then stored record will be worked.
    tanero's Avatar
    tanero Guest
    Answer for ralph;
    your right for guess . after read your post i changed my code as you offer it worked what i expected nearly.
    But some other things i want to do .
    Example ;
    As PORT Bit loop = one of "if" condition is true , its doing its job. while first if working if second condition is true , second wont work and wait for the first one to be released .
    I want ; while the first "if" is true and working ; second "if" true cond happened , it will store request and will do after first if released.
    Any idea ?
    İ thought to use internal eeprom area to store these requests .
    is it usefull to use a like query ?
    I would say they easist way would be to monitor the buttons when your in the if routines and record the button states. Then once you return to the main loop process what ever value is stored in the variable. This will only work for sequencing one button though.
  1. Replies: 9
    Last Post: - 26th October 2009, 20:38
  2. The best way to control a servo with a PIC
    Last Post: - 19th October 2008, 03:44
  3. using all pins of pwm in pic 18f2431
    By jorgequesada in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 22:43
  4. how to control 555 resisters with PIC
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 7th December 2006, 15:27
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
