12f1572
Results 1 to 9 of 9
Thread: 12f1572
    Feb 2007
    Default 12f1572
    Hi everyone,
    I got the PIC12F1572 and compile it with the PBP3.0.4.0
    It runs properly when using INTRC, but with external oscillator it doesn't...
    Although i set necessary configuration (ECH, Clock out pin ...) but still not working.
    Note that i am just blinking an LED in the test.
    DEFINE OSC 20
    PORTA = %00000000
    TRISA = %00001000
    INTCON = %00000000
    PIR1 = %00000000
    PIE1 = %00000000
    OPTION_REG = %00000000
    T1CON = %00000000
    T2CON = %00000000
    WPUA = %00001000
    ADCON0 = %00000000
    ADCON1 = %00000000
    ADCON2 = %00000000
    ANSELA = %00000000
    CM1CON0 = %00000000
    CM1CON1 = %00000000
    ODCONA = %00000000
    PWM1CON = %00000000
    PWM2CON = %00000000
    PWM3CON = %00000000
    DACCON0 = %00000000
    DACCON1 = %00000000
    CWG1CON0 = %00000000
    CWG1CON1 = %00000000
    CWG1CON2 = %00000000
    CWG1DBF = %00000000
    CWG1DBR = %00000000
    clear
    PORTA.2= 1
    PORTA.2 = 0
    pause 900
    goto Main
    Does anyone can help ?
    Rony
    Default Re: 12f1572
    Well, show us the necessary configuration then and tell us what type of external oscialltor you're actually using and how it's connected. Without that we can only guess.
    Feb 2007
    Default Re: 12f1572
Size:  111.4 KBName:  12F1572_Schematic.JPG
    Attached relative pictures
    Feb 2007
    Default Re: 12f1572
    sorry i forget the resonator
    I will put it now
    Feb 2007
    Default Re: 12f1572
    Resonator added to the schematic
    Default Re: 12f1572
    OK, with a resonator I don't think you can have CLKOUT enabled.
    Feb 2007
    Default Re: 12f1572
    The other option is I/O function which is not the case, anyway i just tested it and didn't function.
    Default Re: 12f1572
    You're right, it can't be I/O -but it can't be CLKOUT either....
    I may be wrong but it looks to me as if the 12F1572 can not run directly on a crystal or resonator but rather depends on an external oscillator "module". I suggest you read the oscillator section of the datasheet and see if you agree.
    Feb 2007
    Default Re: 12f1572
    I think you're right, i was reading it now and found out that this PIC is not suitable for oscillator or resonator, it should be used by either internal clock or external clock.
    Thanks for your cooperation.
